..Lotus..curious if anyone..???
Maybe am crazy...but considering getting into a Lotus V8
twin turbo late 90's models. So Curious if anyone knows..owned..
or heard anything about these cars...ok..thanks..
They made a homologation special of that car called "XR" something. It was just for the SCCA race series, and they only made a few, so IF you could buy one of those, it would be a good purchase IF you have the funds to maintain it and keep it (safely) running. They are fragile.
Yes..found this out...
$170 for an oil change.. wonder if could do it myself
$400 for timing belts.... done every 6,000 miles
although Lotus recommends only every 10-12K..was told 6k is better..
Talking to people seems like it will cost..knock on wood..about $2,000
a year to keep the thing going...my family drive Toyota Corollas so
they of course think it's like burning money in a fireplace...
Car is almost exact same price as a used Z51...except the Lotus is
10 years older and has 20,000 more miles..but yes the maintenance $.
Yes..the outside of car is nice...but never knew what people meant
when they complained on here about vette interiors...but when you
see the interior of these cars...then I knew....still the maintenance $.
Just an FYI....while that car is nice (as a collector or street driver), Lotus Exige S are faster in all aspects at 1/2 the price. The Exige S is the fastest street car Lotus has made. It doesn't have the HP figures, but it only weights about 1950lbs. They have new version with 240hp coming out and most Lotus guys are putting bigger pulley's a tunning the cars to 270hp+ without a hitch. They have bullet proof Toyota driveline, so realiability and cost of repair has gone way down to daily car prices. Matter of fact, stock Exige S has turned faster lap times that 400hp Z51 C6 by a few magazines.
The Elise is nice, but underpowered. While another 40-80hp doesn't sound like a lot, in a 1950lb car, it's like adding 100hp to a Corvette.
If you want a fast Lotus, the best ticket is to buy an Elise (lighter than Exige), but slap a modified Exige Supercharger (same motor) and easily get 270-300hp. While it doesn't sound like a lot of power, they are getting 12.2's in the 1/2 mile on street tires and have higher corner speeds than GT3's. The downside is tricky mid engine layout makes it more difficult to drive fast and the car is tight and makes a maita look like Cadillac.
Stax:
Not sure who you are talking to but oil changes (synthetic only) are easy and the timing belt on a V8 needs to be done every 5 years or 30,000 miles. Tension check is recommeded every 10K-12K miles.
Your best bet is a 2000 or newer as it had the AP brakes. The Brembo's are fine on the 1997-1999 but AP are better. Interior on the 1998 and newer MUCH improved over 1997 but you give up some guages for idiot lights.
Keep the engine stock as the pistons are cast and can't take any added boost. Try turning up the boost and you will rebuild it. If the car still has the stock exhaust, drop the "boar anchor" exhast and have a shop weld up straight pipes behind the catalytic converter. You'll thank me.
I've owned five(5) Esprit including two V8. Feel free to call me at (314) 249-3770 if I can be of assistance.
Mark Pfeffer
I figure I can pick up an Elise for 28-30k and put the Katana Supercharger or similar set up and keep my total cost around $35k and have tires and brakes last 3x as long.
Feff
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Just my opinion here. If I had the extra time and money (I don't, however. Everything is currently being spent on the Corvettes), I always wanted to pick up an early/mid eighties Esprit four banger and transplant a Buick turbo in it. Good looks, and some good horsepower in a reasonably priced engine. Oh, well....
I think the car looks great. Other than that, if it drives anything close to the Elise, it will be fun. I rented an Elise in San Diego earlier this year and my dad and I had a blast throwing it around the mountain roads. It was a tight fit, but once in the car, you quickly realize that Lotus knows what they are doing. I wouldn't say it's better than a Corvette; completely different though. Both have their own merits. The Elise had no creature comforts to speak of, but we didn't need any with the top off and the Toyota engine screaming.
Good luck with your choice.
Ken
Ken
My brother ran a Lotus dealer in So cal. He is 5'10 and could barely get in the car.
I am 6'4". So one day he dares me to get in one, so I did.
It took a lot boy and a mechanic to pry me out.
I would RUN away from a V8 Esprit in that price range. I well sorted V8 will usually run at least $50k. Also just like like the early 4cyl car, the early V8 did have some issues while the last V8s are alot more reliable. Maint is not too bad if you know how to treat the car.
An Esprit can NOT be driven like a 'Vette. Due to a weak (but relatively light) gearbox, you can't dump the clutch, no powershifting, and no speedshifting (I learned the hard way :o ). Also, adding a little more boost is not the problem. The problem is when people add 12psi wastergates (generally 13-14psi of boost is the limit of safe, ECU can olny see 15psi boost anyways) thinking they are going to get 12psi of boost. That's not the case. 12psi wategates will give you close to 12psi of boost at redline due to the small turbos being maxed out but they will supply up to 20psi of boost through mid-range (well over the safe range for a non-intercooled car). I've personally seen this.
As for room, People close to 6' and over will have a hard time driving the car without driving shoes and seat modification. It's easier to get in & there's more shoulder room in the Esprit but the Elise/Exige has more leg & head room.
As for the Exige S, it may have a better 0-60 time or it MAY be quicker around a tight track but the tq & top end of the of the Esprit doesn't even compare. Not to mention the Esprit is a GT car while the Elise/Exige is a street legal track car.
