Carbotech AX6 for autox/DD
Anyone running these pads? I am thinking about switching to them autox and daily driving. I am trying to figure out if I should just run them on the front and rear or just go with the AX6's front and bobcats in the rear. I run the car on street tires. (Kumho MX's)
My recommendation is to call them and talk to them about it. They are really friendly people who are more than happy to help. They have a lot of experience with Corvettes and want to be sure you get the pads that will meet your needs. That is, based on my limited experience with them.
I recently spoke with the guys at CarboTech about pad for the street and autocrossing (on street tires like you). Their recommendation was the AX6 if I could tolerate noisey brakes while on the street and the Bobcats if I couldn't. I didn't ask about mixing them front to rear. It sounded like either would be good for the street other than noise.
Can't comment on the AX6 pads, but I have run everything from Carbotech XP9 to XP12 on my car. They all stop fine on the street when cold, don't put out a lot more dust than the stock pads and are mostly quiet on the street. Actually, sometimes they squeak or squeal, but I'm used to it and just don't care.
The only reason I take the XP12's off between events is to save money. The OEM pads still have a lot of life in them. I run a few Solo II events, but mostly track time.
I used to run Hawks, but the HP+ was not quite up to road coarse work. The Hawk Blue was fine on bigger tracks, but the dust and rotor wear was off the charts when the pads were cold. Clay bar was my friend.
The guys at Carbotech can give you a good recommendation.
I ran the AX6 pads front and rear on my 2002 ASP car for about half this past season, and liked them quite a bit. They have very good bite when cold and are easy to modulate, seem to be very rotor-friendly and provide excellent pad life, and dust considerably less than the Hawk HP+ pads I've used for the previous five seasons. And the dust seems much less corrosive than the Hawk pads. I'll probably stay with them for next year.
I am trying to decide between those two pads so your input is/will be great.
ASP is what I am running. What car are you in and what are your mods?
Well mine is a C4 so I don't know if this helps.
I run the panthers for street duty, accidently left them on for an HPDE on Road Atlanta and they worked OK. Usually run XP10's on the front for HPDE and time trials. I'll know later this week how they held up from this past weekend.
Good info. Do you think it worth the upgrade on the rear to go with the AX6's over the bobcats? If you had to put the HP+'s side by side with the AX6's in performance what would you choose?
Between the HP+ and the AX6, I liked the AX6 better. More aggressive initial bite and better modulation, complemented by less dusting. Plus they seem to wear better/last longer and are more rotor friendly.
Have never run the Bobcats so I can't comment on those, but I prefer matched pads front/rear for auto-x.
St. Jude Donor '09
After talking to Matt at Carbotech long ago, I settled on the Panther XP pads for the front and rear (track day) and the Bobcat pads for the front (street). The reasoning was that the rears wouldn't wear much anyway, and even with the front Bobcats on the street, the Panther XPs in the rear were fine. I still have them new in the box as I haven't installed the new front rotors. This is all for my other car. Since buying the Corvette my other car gets very little mileage.
I'd give the guys at Carbotech a call and get their opinion on recommended pads for your particular needs. They are knowledgable and won't try to sell you something you don't need.
San
San
Car is a 2002 Z06, with nearly every mod allowed in Street Prepared.
Eric
