C5 Steering Rack . Any choices?
I'm pretty sure we have no choice, but a re-manufactured one from GM. Is that true? I've gone through a couple of them 2 years ago. Now it's time again. This one is leaking from the boot area.
25-30 autocross and track days a year.
thanks,
Steve
thanks,
Steve
Except for high dollar custom racks, which are usually not convenient, usually don't fit into any class rules, and are $$$$, as far as I know remans are all there is. There are different levels of remans though. Most have had better luck with AC Delco/oem remans then the aftermarket units. My car chewed one this year at the Glen and in the next race that new one was destroyed in a wreck. Expensive little buggers.......
Joe
Joe
^^^ Aside from a full custom rack, the OE's or reman OE's are the only real option right now.
I'd love to see a comodity aftermarket rack, but I don't know if there's that much call for replacement racks, aside for die-hards that are on the track w/ larger than OE tires.
I just bought one from Gene Culley a couple of weeks ago and it ~$755 including freight and a core charge of $50. It was a remanufactureded unit.
Has anyone tried Lucas power steering fluid to resolve their leaks? I had a serious leak with my C5 after one event (reservoir was pratically drained), and I filled it up with Lucas. It took a few days, but the leak stopped and held up great at my next open track event. It might not work for everyone, but it is worth a try considering the cost of replacement.
http://www.lucasoil.com/products/dis...tid=2&loc=show
St. Jude Donor '10-'11
I should know this, but ... ^
I believe I have a PS cooler on my C5Z ... finned and about 4 x 14" ...
Do all C5's have or is this unique to Z06? :o
Is it still working?
I called up Rock Auto and they have a lifetime warranty on there steering racks. I will probably order one just in case this Lucas stop leak doesn't work.
thanks,
Steve
And, swap the pump . . pull some of the heat out of the system, and it's amazing how things end up working.
. . . now all we need to figure out, is how to solidly mount a remote fluid tank (pref a tank that looks like a giant heatsink)
