best brake proportioning valve setup??
i got a larger bore brake master cylinder off of a chevy truck, im going to put it in the c4....i ditched the abs so i think a pv is a good idea..any ideas any picks...
MC bore size is a balance between pedal effert and pedal stroke (distance). I opted for the 1" bore. I assume you have the 1 1/8" or 1 1/4" bore for more effort and less travel. I prefer the reverse.
Why did you ditch the abs?
I use the turn **** Wilwood prop valve mounted in-car. I dont see a distinct difference between brands. More of a decision between lever vs ****.
