scatter shield for road racing?
My first thought is 'No', but then again I don't know too much. Is a scatter shield a good idea? I need to buy a bell housing, so its not just an upgrade...
Thanks,
Matt
Thanks,
Matt
1 Post
St. Jude Donor '08
If you are using an aluminum flywheel you should get a scattershield in case your flywheel decides to self-destruct. They have a habit of splintering when they go and you don't want to get hit by the scrapnel.
If you have a steel or light-weight steel flywheel you can probably get away without a scattershield.
Thanks for feedback, interesting point, had not thought of an aluminum flywheel. I'm looking to get a billet steel one
I assumed that scattershields were for 1/4 mile guys who really abuse their clutch and not so much for road race where you don't want the rear tires braking loose in a turn...
Any other opinions?
Any other opinions?
Blown flywheel story
At a vintage race at Green Valley raceway near Fort Worth in October 1984, Carrol Shelby drove a race Cobra owned by Rick Nagel. During the race the flywheel of a Shelby GT350 Mustang blew up just as Shelby was passing him at the end of the drag strip front straight. The flywheel explosion took out the entire hydraulic system of the Mustang, and a 4 lb piece of shrapnel went theough the left front cowl of Carrol Shelby's Cobra, and through the driver's compartment, missing him by inches.
Yes, I would (do) run a scattershield.
If your clutch ever exploded or suffered some kind of catastrophic failure it could literally kill you in the vette since the floors are made out of balsa wood and thin aluminum sheet.
Also all of your major wiring harnesses run along that area and if they suffered damage your car would be probably be totaled.
RPM Transmission sells them for around $450.
there was a thread on CF years ago where a guy's C5 clutch let go. lots of pics. the majority of the pressure plate went up through the dash and through the windshield.
there was a guy at road atlanta about 2-3 yrs ago that lost a leg on a clutch explosion
It looks like this unit weighs about 22 lbs for the C5 if I read that right.
It is still questionable legality in something like SCCA T1 I imagine, not to mention the weight being undesirable. But safety is a good thing, too.
SFI Certified @ 6.1
RM-6035 - Chevy LS Bellhousing/97-04 Corvette manual
Height = 5.786
Trans. Bore Ø = N/A
Engine = Chevy LS-1, LS-2, LS-3, LS-6, LS-7, LS-9
Trans. = 97-04 C5 Corvette manual
Clutch Ø = 11"
Flywheel = 168 tooth or 153 tooth
Weight = 22#
Full engine plate and grade 8 bolts included
