Best Power Steering Fluid??
Old 12-13-2007, 06:53 PM
NemesisC5
Support Corvetteforum!
NemesisC5's Avatar
Default Best Power Steering Fluid??
I'm changing my clutch & brake fluid to Motul AP600 and want to know what you guys are using for Power Steering. Any advice will be much appreciated
Old 12-13-2007, 07:12 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
WE use the Redline PS. Works like champ!!!
Randy
www.dougrippie.com
Old 12-13-2007, 07:18 PM
NemesisC5
NemesisC5's Avatar
Randy
www.dougrippie.com
Big Thanks Randy
Old 12-13-2007, 07:33 PM
c4cruiser
c4cruiser's Avatar
I also use Redline PS fluid in my 87. I had to swap out the rack and pinion unit last year and used Redline fluid on the install. No more noises at the end of a track day.
I do flush it out at the start of each season so I have fresh fluid. Maybe overkill but it may help keep the original PS pump working for a few more years
Old 12-13-2007, 08:32 PM
hisvett
hisvett's Avatar
St. Jude Donor '14-'15
Randy
www.dougrippie.com
Old 12-13-2007, 09:53 PM
astock165
astock165's Avatar
Another vote for Redline. Got rid of the cold morning "sluggishness" in my C4.
Old 12-14-2007, 11:56 AM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
I went to Valvoline Synthetic Blend and then to Redline - after reading a BUNCH of testimonials for different brands.
Old 12-14-2007, 12:13 PM
Aardwolf
Aardwolf's Avatar
I have the Redline in mine as well. There is no PS cooler on mine and the pump used to really start to moan loudly after a few laps. With the Redline fluid it only moans softly. There was a big difference and it still has not blown up, which surprises me.
Old 12-14-2007, 02:47 PM
NemesisC5
NemesisC5's Avatar
Redline in a shutout so far
Old 12-14-2007, 11:27 PM
Mojave
Mojave's Avatar
Redline.
Rumor has it that the Redline power steering and ATF is the same. Some of my Redline is red (like it's ATF), other times it clear.
Old 12-15-2007, 10:54 AM
Vette Ed
Vette Ed's Avatar
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
Redline here
To Best Power Steering Fluid??
Quick Reply: Best Power Steering Fluid??
