Header install help...
Old 12-14-2007, 04:16 PM
wallyman424
wallyman424's Avatar
Default Header install help...
So, I've encountered some problems while installing these headers. The first was that the line to my accusump was inconveniently placed where the header wanted to be. Thats an easy fix though. I've ordered some new fittings and will deal with that later.
The PITA is this little sensor plug. I believe its for oil temp. The adapter block for the oil cooler nonsense puts the plug in a non-stock location, thus the annoyance with the headers.
What I need from you folks are ideas (I know, what am I asking you for ).
First off, is this the oil temp sensor? if not wtf is it.
Secondly, can i just destroy the plastic part of the plug, just leaving the male end and a couple wires? wrap all that stuff in some heat protector and be done with it.
The offending plug is below, to the right of where the oil filter should be.
Old 12-14-2007, 04:23 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Wally,
What block adapter is it? What headers? I have played with them all at one point. If you have to you can move the sensor, and run a AN line to it. Yes it is a Oil temp sensor.
Randy
Old 12-14-2007, 04:28 PM
wallyman424
Originally Posted by Randy@DRM
Wally,
Randy
block adapter, no idea. headers, ebay cheapo headers. dont judge me on my frugality.
i'm intrigued by how i can move the temp sensor though.
Old 12-14-2007, 05:50 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Ok, A FCM2246 is a -6 to 12mmX1.5 fitting. This will get you out of the block adapter. Then you can build a AN line to a remote location. This is were it gets tricky. Either find a -6 male to 12mmX1.5 fitting which will be kinda hard because the sensor is pretty long. You could either make one or have someone else make one. A tube of AL and a tap is all you need. If you build a female to female fitting then you will need one more FCM2246.
Or find some trick high dollar pretty adapter to go into your oil cooler line.
Randy
PS I Have a hard time explaining it, call me if you need more info.
Old 12-14-2007, 06:14 PM
wallyman424
Randy
i see i see. I dont think i can use anything coming out of the existing port in the adapter block. My best bet is probably to Tee off of the HUGE oil cooler AN line. Then I can probably find some adapter piece to go from the huge AN an male off the tee to a 12x1.5mm.
I'm going to try and mess with the actual plug itself though. It would seem that if i could get rid of the quick disconnect capability, and just directly connect the wires to the sensor it would work fine.
Old 12-14-2007, 06:55 PM
Falcon
Falcon's Avatar
Whoaaa, there Cowboy!
Headers? Do I see additional HP in your future?
8.7 : 1 ! Remember, that's the magic formula!
We're watching!
Old 12-14-2007, 07:01 PM
wallyman424
We're watching!
shhhhh, dont worry about it.
I'm just trying to get my tired old motor up to par. And getting rid of that 100 octane crap.
Old 12-14-2007, 07:56 PM
Oyishdog
Oyishdog's Avatar
tired motor!! Dont talk to me about one of those!
Old 12-15-2007, 08:41 PM
3X2
3X2's Avatar
Remove the oil temp sensor and tap the hole with a 1/4 npt tap and JB Weld an internal allen head 1/4 npt plug. Wire tie the connector out of the way. If you want the oil temp sensor functioning, relocate it in the oil cooler return hose and extend the wires to reach it. Get one of these fittings in whatever dash size your oil cooler hoses are
(probably -10 or -12). This picture is of a -8 fitting.
http://store.summitracing.com/partde...5&autoview=sku
Cut the end of this fitting that would be the leg of the "T" and weld a piece of aluminum to it, tap it for the oil temp sender and install it in the return hose. The tap is a 11mm x (I forget either 1.0 or 1.5).
Mark
Old 01-03-2008, 07:13 PM
wallyman424
thanks for all the help guys. I just fired her up. It scared me a little bit and I might need some earplugs, but good lord does it sound good.
and my oil temp sensor is intact!
Old 01-03-2008, 10:22 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I wish I'd have seen this sooner. Many of the headers come really close to the temp sensor. btw, DRM's block adapter works great, and clears my LG headers very well.
Wallyman, you running an LS6???? You should have plenty of power for ST2 unless you're running a 90,000mile LS1 like me.
Old 01-03-2008, 11:29 PM
wallyman424
well i'm at 360 rwhp with a 100 octane tune. the 100 octane gas is KILLING me $$ wise.
I figure with these headers, I can get a nice safe 93 octane tune running about 370-375 rwhp. Thatd put me right at 8.7
Old 01-04-2008, 10:19 AM
spazegun2213
spazegun2213's Avatar
when are you getting it tuned? and with who?
Old 01-04-2008, 04:28 PM
Jaymz
Jaymz's Avatar
Wally.. Don't forget that the Dyno at MidOhio reads about 5 HP higher than others. Don't too close the the 8.7 magic number.
Old 01-06-2008, 01:39 AM
wallyman424
yeah, i'm gonna give myself a nice safe buffer.
i'm just so glad that everyones so concerned for little old me.
Old 01-06-2008, 01:12 PM
Falcon
Falcon's Avatar
Hell, if you were slower we wouldn't care. But as fast as you are, you don't need any more horsepower!
Old 01-06-2008, 01:30 PM
AU N EGL
AU N EGL's Avatar
Mark
From the MAN who knows .
To Header install help...
Quick Reply: Header install help...
