Hitch-mounted Tow Hook Options
I know the Tow Hook topic has been beaten to death lately, but I searched and found nothing about a hitch-mount option. You know, a tow hook those of us who already have a great, solid, strong mounting point like our hitch could just slide in the receiver and go! I see them all the time on my buddies' wheelin' rigs, but obviously that's a much larger receiver.
It seems like a much more secure location (4 giant bolts going into the frame) than the exhaust hanger location. Then again, the hitch is only rated for 200lbs tongue weight and 2k lbs pulling. Put come on, if the exhaust hanger can do it...
Good idea, or a risk of damaging the frame?
And while I have your attention... any front options that won't require me to cut up my Z06 screens?
-TJ
-TJ
I think it is a much better idea than the exhaust hanger bolts. We make the tow hooks on a HUGE press and form them to fit tight to the rear facia and come out between the liscense plate filler and the fron facia we then weld them to the rear bumper and fom a plate to cover the area of the hook and span a larger area of the bumper(frame) so they will not tear away the frame. The biggest problem with welding the hooks is not the hook or the weld it is that the material in the frame is so thin it will tear away.
Former Vendor
Sounds to me like a good idea. Welding a hook on is a big no-no. The 4X4 guys around here will not let you on the trail unless they are bolted on. The way Dale did it was ok.
Randy
PS IF You are really in the crap(trees, mud, deep pea gravel) hook on to something other then a tow hook.
Randy
Come to think of it, would the safety chain loops on my hitch qualify as tow hooks!?!
Not an elegant solution, but I guess I could use a receiver adapter:
Then one of the larger ones I see on rigs:
-TJ
-TJ
I had a fab shop make one for me out of bar stock and a couple of 2" rings. They used the hitch bar as a model to round the edges and position the hole. Painted it red and slid in in. Haven't had to use it yet but I'm confident it will take the load.
What's the trailer hitch rated at? How many bolts holding it in? How much does your car weigh? Without thinking too in depth, seems like a bad chance to take since your car becomes the trailer being yanked.
"AlohaC5" Senior Member
Did I run with you at Watkins Glen with PDA in mid-September? I saw a guy with a blue Z06 that had a custom tow hook made from a hitch bar. Very nice!
If you look at where everybody else is mounting them on C5s (the exhaust hanger bolts) it’s 2 tiny little studs. Everybody is saying they’re good enough… but I have my doubts. The hitch is many many multitudes stronger, but the consequences if its strength is exceeded could be severe.
-TJ
