Anyone have any ideas? Here is the story...I'll make a very short
A little over a year ago I replaced all my C5 suspension with new '04 Z06 stuff. Everything has been beautiful so far except a few weeks ago I noticed that the L/F corner is all the sudden lower by almost a full inch! I have checked every pc. of the front end and can find nothing even remotely wrong! And Now I have reset my ride height but the front adjusting bolts are not even remotely close as far as threads measuring the same!!! I went 4 full turns clockwise to raise the l/f corner and almost 4 turns counter clockwise to lower the r/f corner!! WTF? The car now sits perfect and handles perfect! Help!!! Anyone? Should I be worried? Is there anything else I should be looking for? And why the heck is the R/F higher than the L/F. From my notebooks, the r/f corner somehow moved up!
Shahram
Shahram
Shahram
Shahram
maybe you pushed the left front down with too many right hand turns??
ya know 3 lefts could make a really screwed up right...
Well I was also thinking shock but they are still tight and the adjusters are working!!!! I know I'm not the smartest bear but I've looked and looked and looked! I will be going coilovers before long but I don't want to complicate things.
plastic springs sag after awhile or the rubber pad on adjuster has taken a vacation
i say shock was stuck or sway bar was stuck...if it was the spring it would not have come back... outside chance stuck balljoint or bushings but i really doubt those
what did you change? springs, sways, shocks, spindles, A arms, tie rods everything? are thw wheel hub/bearings any better?
what is the main difference between c5 and c6 suspensiom? i thought they were almost the same?
Shahram
Springs are good, bushings are good, suspension bolts tight. I finally got it level and will take it for a ride this weekend. For whatever reason, it looks like the R/F corner actually somehow rose up!!!!! I'm grabbing my ammo box right now!!
Shahram
Shahram
Update: Well, no matter what I do the r/f is about 1 inch higher than the l/f!!!! No matter how I adjust the adjustment bolts...seems to make no differance!! I did notice today that the adjuster bushing on the l/f seems to be much softer and somewhat distorted!! So maybe I'll replace those and start over and reset ride height. Anything better than the stock material?
Shahram
Shahram
