Road course guys - Z51 OEM tires or the Firestones Run-flats OVT?
I did a lot of searching, mostly just saw that the Firestones are quieter and seem "as good if not better" than oem, but no real reference to cars that are tracked on road courses.
Can anyone chime in on how the Firestones compared to the GYS during track events? For the cost difference, if they are about the same performance wise, or even a tad less, I would still rather save the $700-$800.
Thanks,
John
Thanks,
John
"AlohaC5" Senior Member
John, I think most will recommend not going with a EMT (Run Flat) tire for road course events since they don't provide optimum performance. If you're looking for a dual-use street tire that can also provide really good performance on the track, then take a look at the BF Goodrich g-Force T/A KD or Falken AZENIS RT-615. Tire pressure sensors (TPS) work with non run-flat tires. Mike
the GY's have rediculous grip and performance for a run flat. Before I traded my c6 in, I went to the firestone tires - the firestones were great for street and much, much quieter. I did not take them on the track, so I cannot comment, but i would assume the performance not to be a good as the GY's (tread wear is higher (less sticky) and the tread is very deep and wide (less stability))
You have a couple options: (1) C5/C6 Z06 do not have EMT tires. GM provides them a GM Tire Repair Kit #22732102 (Compressor kit w/sealer) for $121.90; or (2) order a matching C6 repro wheel from TomzWheels - do a search on member "TomLzzz" or House of Wheels (both forum vendors) for a very reasonable price with matching tire (for spare). I never used an EMT tire on the track. Hopefully, someone who has will chime in with a recommendation.
oyishdog, thank you.
Mike, I will have extra rims/tires (if I don't sell them) left over after I purchase new tires for the new rims I just got. Can I use a stock front wheel and tire on the front or back in order to "limp" the car home? is that safe to do? I'd imagine its similar to a normal car using a donut to get home.
Maybe non-runflats and a spare or repair kit is the way to go.
Thanks,
John
Thanks,
John
The C6 Z06 comes with runflats but I recently went to Michelins which don't have matching sizes in runflats so I went to a set of non-runflats; 285 fronts and 345 rears. I understand that Michelin is coming out with Z06 runflats.
If you decided to get an extra set of wheels and mount up non-EMTs you can run them with or without TPS and just carry an inflator/repair kit. For everyday street keep the runflats (but not GY OEMs).
John,
I've worn out almost 4 sets of FS W/O's on my C5Z at the track in the last 2 years, and I think they are not only a great economical tire that will last forever, but it is a great tire for learning car control as well.
There have been alot of debates on CF about why someone would choose the W/O's vs. a better tire like the Goodyear's, and faster lap times will not be one of the strong points of the FS's.
But, if you are looking for a long-lasting tire that gives great feedback, doesn't do anything quirky, and once you master them will give you lap times just a few tenth off what the more expensive tires will do, then I recommend the FS's.
My car is primarily a track-only car and I use Kumho 710's the majority of the time, but I always like to throw on the FS's for a few sessions and have some fun sliding around the track. I can usually embarrass alot of other cars using much stickier rubber with the FS's mounted, and it's nice to know that they will last about 3 times as long as the Goodyears!
Here's a link to the Safety Seal kits, the one I got had 30 plugs in it:
http://www.safetyseal.com/store/autokits.htm
HTH, and have a good one,
Mike
guys, big thanks for all the additional replies. Much better response here than in the general section
I'm thinking non-run flats, maybe the BFG KDs or some Kumhos, get a flat repair kit (perhaps the GM one recommended), AND maybe also bring a spare front rim/tire with me to the track, that way it can be used on the front or the back if absolutely needed to limp home. I also have to look into the Falken 6115s because they did not come up as recommended for the C6 on the tirerack site.
As for the TPMS - I heard on the C6 there is no way to get around using them - that the computer/DIC basically freaks out if they are not showing correct pressure, is this true?
So that was 3 working sensors and one that would send 0psi or wouldn't train with the Bartec or ... some folks say if the car can't communicate with any of your sensors it'll leave you alone. I haven't any experience with that because I couldn't find a way to make the car forget about the sensors it already knew about with the simple Bartec tool. Aaron Pfadt suggested a Tech2 might work for that.
David Bonar at Northstar Corvettes in Mountain View, CA thought he saw something in the Technical Manuals about disabling the entire system but I haven't got the procedure from him as when he got in touch with me during that Thunderhill day the sensor had magically come back to life for a couple of sessions. Other folks have said similar about a way to disable it, but I don't know if that comes as part of a "tune" or something you access through the DIC...
IMO, running a C6 with a functional Tire Pressure Monitoring System on track that lets the car decide when it's going to force a "Reduced Handling" mode is pretty damn dangerous. GM needs to do something about this and give us a way to disable it. I'll still do it, of course, but right now I'm scrambling to get my TP sensor issue sorted for Spring Mountain...
There is a way. Friend of mine here in raleigh has made severl.
He took a 3" diameter PVC pipe about 12" long. and two end caps that could be unscrewed. Drilled 4 holes in so the Schaider of the TPS valve could come though the side of the pipe. sealed the valve with silicone.
Labled each valve with its # and RF, LF, RR, LR
Made the pipe air tight. put in 32 psi in the pipe. Mounted the pipe between the two seats, under a harness bar. in back.
Then Programed each TPS. Works like a charm
and can switch wheels at will as the TPS pipe, never leaves the car and always reads 32 psi.
And thank you again for the TPMS info - that is .... interesting! haha, and definitely something to think about.
I suffered a LF Tire Pressure Sensor failure/flakey behaviour at my last track day. Down right scary. Sensor freaked when I was already doing about 100mph and heading for T10 at Thunderhill... brake, turn-in, and have the car slam on the brakes and then refuse to accelerate out of the corner. I'm very glad I had put some significant distance on the Audi S4 I had just passed because he surely wouldn't have expected me to be doing 45mph where I'm typically doing much more.
Labled each valve with its # and RF, LF, RR, LR Made the pipe air tight. put in 32 psi in the pipe. Mounted the pipe between the two seats, under a harness bar. in back. Then Programed each TPS.
Guys, a few new concerns. Lowering a Z51 - seems like that may not be a good idea based on some posts and threads I've seen on here while researching. Literally only thinking of doing 2.5 turns front and back and it doesn't look too low. Should I be staying with stock ride height for optimal performance or can someone point me in the right direction with that? if I go lowered, the main consensus is that it would require an alignment as well.
Brakes - I had an instructor say that the stock brakes should be good, just upgrade pads. For the Z51, do most of you find this true or should I eventually be looking at upgrading to a BBK - Brembo, Wilwood, or Z06 takeoffs? I typically drive my car at 7/10ths to 8/10ths as this is an expensive toy to wreck.
Lastly, although Too Tall Bob has been great with giving me info on the Firestones, I am still on the fence between those and the KDW2s that are on Tirerack. I could always bring a spare rim and tire with me to the track either way.
What say you guys? thanks for all your help on here, this board has been very good.
