*** ECS - LS7 build for my C5 ***
St. Jude Donor '05-'08
Update: 02/09/2008 - Car was on hold to finish customer cars, but now it is in full swing again. New Pics are up today. Engine is built and next week the old engine is coming out and the new going in
I am sure that many of the general CF people have never saw an engine build so we decided that we would document my LS7 build for my 01 C5. We are going to do our best to show pictures and explain what we are doing and/or why we decided to go one direction over another.
I will continue to update this thread on the progress of the build, but you can follow the entire build which includes commentary, pictures and research at
http://www.ecsracing.com/ecsracing/f...splay.php?f=77
Some Background
My last track day at WGI my timing chain went and it was time to make a decision on what to do with my car. My ECS H/C 346 had over 3 years of road racing and over 50 1/4 mile passes. I was not happy that a double roller broke causing me to make a decision on a new setup, but such is life and so the decision was to either try and fix what I have or look into a new engine. A new engine that sounds so nice (that was a quick decision )
Originally we were going to install a 402 in my car. ECS has proven success with this setup in different street applications, but ECS was concerned about an engine that is almost completely dedicated to Road Race Tracks (15-20 track days per year) surviving with a standard oil system so they started to investigate Dry Sump systems (there is a write up on Dry Sump systems at http://www.ecsracing.com/ecsracing/showthread.php?t=442 ).
At PRI this year Doug@ECS found a ton of valuable information on Dry Sump systems, unfortunately every system that he found would mean that I would lose the A/C which I was not willing to do (it is still taken on the street in the summer and I wanted A/C). Then out of no where thrown on the table was the LS7 setup. GM has already developed a Dry sump with the LS7 setup and we all know there is plenty of power on tap with a 427. I could also keep my A/C so we looked into it further.
Sure the GM LS7 dry sump solution is probably not as good as some of the aftermarket systems that Doug looked at, but after doing some research I personally felt the GM solution (with a few mods) would be more than adequate for what I do. Of course only time will tell if this is true or not, but many LS7 owners are happy with their cars on the Track.
Right now we are just starting to get parts in for the build. Here are some teaser pics (more at ecsracing) which should get your blood pumping:
7.0L BABY - Front
Where are we going to fine Pistons for this
Crank
Oil pan - dont need much with Dry sump
Some Background
7.0L BABY - Front
Crank
1 Post
St. Jude Donor '08
I always thought one of the big drawbacks to running a C5 on the track was the lack of a dry sump system due to all the high G-forces. While an accusump helps, it is a less than perfect solution. One of many reasons I decided one is better off with a true race car from the get go.
What kind of numbers are you hoping to get out of this motor? Planning on making any improvements to the driveline to handle the extra torque and HP?
Bob, couple of quick questions.
Did you guys buy a brand new long block or did you get one used? I am curious as I am sure these things are now floating around US junkyards from totalled Z06's. It look like it had oil in the pan. I am curious as to what a used LS7 would go for nowadays. I think new they are $12k.
Are you going to use stock internals or are you going forged and all that? Did your block come with all the titanium internals or do you have to provide that extra?
Good luck with the build! With this motor and LG coils your going to be untouchable!
With the LS7 I am also stuck with their 2 stage design (1 scavenge and 1 pressure) if I went aftermarket I could get more stages. Many I saw had at least 3 stage setup which would have 2 scavenge and 1 pressure section or a 4 stage.
I am going to say 550rwhp for now . I am less interested in peak HP versus TQ and driveability, but we will see.
As far as drivetrain - I am going to upgrade to the Tex Exo-skel clutch. I already have 3.73 gears with hardened output shaft, RPM Tranny and I will keep the DTE Brace on. For now I am not touching the torque tube.
We will use the LS7 crank with forged Pistons and Rods. I did not go with titanium because frankly they are not easy to get and I didnt trust used.
We will also use ECS Custom NA Cam, Trick Flow heads, American Racing Headers, FAST 90/90 and whatever else I can throw in there.
Over 500, but how much I dont know.
H&C 427 I'd be looking for 600 rwhp. I see 581/521 stock heads on the board here add heads and your at 600+ Tires will be going fast! What size are you going to run? I see many modded 427's in the NE this year Sure be fun. Doug making 427 or bigger?
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
We are leaving it a 427 John, we are also not going for max numbers, kind of building it like a boat motor. Made to make big power, yet be able to handle long periods of high rpm use. We are going more for the flat torque graph, rather than peak hp numbers. One of the diferences we do when building a road race engine compaired to a drag engine.
