NE One know where to get spring eye pads for C4 front leaf?
Old 01-17-2008, 10:40 PM
steve40th
steve40th's Avatar
St. Jude Donor '03 & '05
Default NE One know where to get spring eye pads for C4 front leaf?
Its part number 39 in this photo. Mine is bad and spring is too.
Old 01-18-2008, 02:21 AM
gkmccready
gkmccready's Avatar
www.gmpartshouse.com (Gene Culley)? or maybe www.vbandp.com?
Old 01-18-2008, 02:27 AM
steve40th
steve40th's Avatar
VBandP didnt, and I tried another dealership, GMpartdirect (Flow Chevrolet), and they wanted my VIN?
No luck so far
Old 01-18-2008, 02:44 AM
gkmccready
gkmccready's Avatar
Gene will likely ask for your VIN. It's their way of making sure you actually get the right part. They even wanted the VIN when I called to order some interior pieces...
Old 01-18-2008, 03:08 AM
steve40th
steve40th's Avatar
Makes sense, thanks
Old 01-18-2008, 08:08 AM
astock165
astock165's Avatar
Just out of curiosity, what went bad?
All the springs I have are just sheet metal plates bonded to the top and bottom surfaces of the spring. They had 1" square rubber pads bonded to the bottom side that ran on the A-arm.
Old 01-18-2008, 09:10 AM
mrc24x
mrc24x's Avatar
If the spring is bad and you are'nt looking to upgrade to a performance spring (VBP,etc) then just call a corvette salvage shop (left side of screen) and buy a used spring. The pads are bonded to the springs so it should come with the new/used one.
Old 01-18-2008, 11:08 AM
steve40th
steve40th's Avatar
My replacement spring doesnt have the pads (My fault), and the one in tthe car does, but the spring is bad. Maybe I can get it off the spring in there?
Old 01-18-2008, 01:41 PM
astock165
astock165's Avatar
Probably worth a shot. Good luck.
Old 01-18-2008, 07:19 PM
mrc24x
mrc24x's Avatar
Steve, Another option is to just buy a thin piece of "generic" rubber. Cut it to fit and epoxy it to the lower control arm. A lot of guys cut the pad that you are looking for off or shave it a little to lower the front ride height. Just an thought.
Old 01-18-2008, 10:00 PM
steve40th
steve40th's Avatar
Thanks Guys, sometimes I guess we feel it is a "uber" unobtanium part since the General makes it.
To NE One know where to get spring eye pads for C4 front leaf?
Quick Reply: NE One know where to get spring eye pads for C4 front leaf?
