Any home shop bender for roll cages available?
Former Vendor
Looking into rebuilding my race cage and to long a wait for any shops around here.
I can weld decently enough but need to know of any affordable home shop class benders that will handle 1.750x.095 DOM, max bend will be 45 degrees.
Any ideas let me know!
Rick
Rick
I will once again again recommend http://www.tcdesignfab.com/ in NorCal. You're in Utah. Tony isn't too far away, and he's absolutely awesome.
Former Vendor
Thanks again I have been sick, my business is going crazy, not enough rest, forgetful lately.
I will give him a call and maybe I can just have the tubes bent if they are to busy to do the install. I weld better than some work I have seen pass inspection, allot better than some of it in fact!
I just do not want to wait as it holds up a ton of other projects and I am probably pulling off the roof tomorrow or Sunday to sway to, something else
Then again, I really do not have the time to take the car there and then go get it and just paid to have it shipped once already. There is one more shop option in Utah but not holding my breath while trying to get in.
Rick
Rick
Definitely call Tony. I wish I could say my name would make a difference, but it won't. His cage work is amazing. I love my RX7 cage, and I will definitely work with him if I do the Miata or the Corvette. His cages are known as "the best" in NorCal right now.
Don't feel bad. He's not the cheapest down here, but from everything I've seen, and from my own cage, he's regarded as the best. If you have trouble I can dig up some other local (NorCal) cages guys... they've done a lot of Mazdas, but they're good folks.
Oops. Apologies for misinterpretting the question. I thought you were looking for a "bender" the person, not the tool. :-)
There's more to getting a roll cage right than just bending the tubes and welding them together, though. Everything needs the correct angles to actually work in a crash and keep you safe...
Former Vendor
Thanks guys, I found the setup I want, software chassis design as well for proper angles, local buddy has the same setup he has not used yet so buying his and ordering one for him so I do not have to wait
http://www.xtremecrawlers.com/catalo...kage-p-39.html
I am getting the mid pack software, 1.75 240 degree die, POD tool not listed and the industrial notcher.
I will practice my welding until excellent at it, will built beyond spec, going to be fun
And I can build my son and later my daughters setups when they start racing.
My car will be well under 3k lbs, 095 tubing is going to be used to save even more weight and legal, and safe
Fun times ahead!!!!
Rick
Fun times ahead!!!!
Rick
http://www.lowbucktools.com/benders.html
I've got one of these. If you are doing a single cage, especially a simple rear bar only, it works great. If you are doing serious bending, your arms will wear out for pumping.
While it is hydraulic, and manual, it has a nice mandrel and makes very clean bends.
