holly crap!!!! it was broke!!!major disaster
was cleaning the break dust of the suspention and stuff on the front left and saw a crack in the part that the steering control arm end bolts into what caused this..over tightening ??? or what ??? thje bolt wasnt that tight .. it was the same side the bearing failed on..the o2 zo6
Received 8,928 Likes
Can you provide a picture showing where it cracked? Could be a specific spot we need to add to our pre event checklists??
Bill
Bill
Premium Supporting Vendor
Never had that happen to me, but obviously will add it to the things I look at frequently...
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
right to the left of the rotor you can see the tie rod. there are two metal portions in the joint, the bottom connects to the tie rod and the steering rack. the top is the front ear of the spindle. From what I gather, trackman has a crack in the spindle ear.
heres another view
heres a nice picture without the rotor
You should always perform regular visual inspections of all suspension components if you regularly track your car!
I'd expect that an offroad's more likely the cause than overtightening. That's a fairly beefy part. Was King Kong turning the wrench?
I know a lot of guys at the track that always overtorque bolts. They usually have a couple of failures per year.
I use a torquewrench on all suspension and critical bolts on the cars I work on.
I've seen check sheets from some pro crews that are used before every race for critical nuts and bolts, all are checked with a torquewrench and checked off.
http://www.davidfarmerstuff.com/C5torque.pdf
"Steering linkage outer tie rod end stud nut" 16lb-ft, 160deg, 33ft-lb.
more of a jakazz than king kong at the wrench .. i noticed it as i was going ti tighten it . the car had only ben off for a second at wgi.. more of an over the grass than a run off..the breaks pooped goin into the chicane.. when i torque the new one what should i shoot for.. ill probibly drill and saftey wire it ... ala the old superbike days
thanks fellow c4 er .. this time it broke on the z .. the c4 is at the chassis shop for a new full cage and power plant #6 is allmost complete ill post some picks as things get done!!
1) Over Torquing
2) Beating on the rod-end with a hammer to seperate it from the spindle.
David Farmer put the torque spec up- follow it! And don't beat on it with a hammer!
