Am I Wasting ATE BLUE ????
Old 01-20-2008, 09:27 PM
Dirty Howie
Dirty Howie's Avatar
Default Am I Wasting ATE BLUE ????
Before each track day I bleed my brakes when I check the pads and make sure all brake bolts are tight.
I pump the rears 10 times and the fronts 13 times. I don't measure how much fluid I am replacing.....but I refill the reservouir after each wheel as it drops about 1/2 inch. The fluid always looks clear and blue.
Stock calipers.
Thanks,
DH
Old 01-20-2008, 09:53 PM
gkmccready
gkmccready's Avatar
I never feel like I'm wasting brake fluid so long as (1) I have confidence in the brakes, and (2) they stop the car. I buy Motul RBF600 by the case... if I was using SRF I'd probably watch how much fluid I used more closely...
If you were trying to pinch pennies you probably needn't bleed out that much if the fluid coming out looks clear and good and has no air bubbles.
Old 01-20-2008, 11:53 PM
sothpaw2
sothpaw2's Avatar
Where is a good place (good price) to get the Motul by the case?
Old 01-20-2008, 11:57 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
I typically to 5 or 6 pumps per wheel before each event. Like said above... do whatever gives you full confidence in the brakes.
Old 01-21-2008, 12:01 AM
wallyman424
wallyman424's Avatar
i'm not going to inform you guys of my brake bleeding (in)frequency. i fear that some of you might have heart attacks.
Old 01-21-2008, 12:03 AM
Cobra4B
Cobra4B's Avatar
^ haha... I don't do it nearly as often as some on here. Some say do a full brake flush before heach HPDE and bleed between each session, but I've never ever had to do that.
Old 01-21-2008, 12:05 AM
wallyman424
man, if i told you guys how "often" i change my oil, **** would really hit the fan.
Old 01-21-2008, 12:08 AM
Cobra4B
Cobra4B's Avatar
^ What you don't swap it after every race and twice for good measure?
Old 01-21-2008, 12:09 AM
wallyman424
yeah, and after i change all the other fluids in the car, i give myself an enema for good measure.
Old 01-21-2008, 12:25 AM
Dirty Howie
Not trying to pinch pennies.
So 10-13 pumps seems like more than alot of you guys are doing.
How much of the fluid really gets cooked ...... just whats in the caliper and hose near the wheel.....right???
DH
Old 01-21-2008, 01:18 AM
Sidney004
Sidney004's Avatar
I am a 5-6 pump per front wheel guy myself. The rears rarely overheat and most of the time do not require much bleeding; if I bleed them 4-5 pumps. The only fluid that gets cooked is in the caliper; Motul 600 has a marked discoloration when overheated.
Old 01-21-2008, 02:12 AM
rustyguns
rustyguns's Avatar
hahahaha sound like me! i wait until they feel soft then i bleed
bleed baby bleed !
Old 01-21-2008, 02:13 AM
rustyguns
rustyguns's Avatar
sign of a true race car driver!
Old 01-21-2008, 08:58 AM
spazegun2213
spazegun2213's Avatar
ummmm thats something i really didnt need to know wally!!
haha, granted think of how much oil you have in your vette.. odds are its more than enough to do 1/2 the season and not worry about it..
as for the brakes.. well you dont really use the much anyway.. right?
Old 01-21-2008, 09:09 AM
Mikelly
Mikelly's Avatar
My Vette's brakes were always flawless in their ability to stop the car deep into the brake markers... I'd always bleed the system before a track weekend, and it always worked, because that was the only thing I could count on working properly with my c5. About 6 pumps per wheel is all you need.
Mike
Old 01-21-2008, 11:36 AM
gkmccready
gkmccready's Avatar
http://www.pegasusautoracing.com/gro...pID=BRAKEFLUID
I'm sure there are a bunch of places. I'm still going through my Motul from before the price increase.
Old 01-21-2008, 01:31 PM
Falcon
Falcon's Avatar
TMI!!!!!
To Am I Wasting ATE BLUE ????
Old 01-21-2008, 01:35 PM
wallyman424
Originally Posted by Falcon
TMI!!!!!
speed secrets jody... speed secrets.
Old 01-21-2008, 01:58 PM
Carolina C4 Racer
Carolina C4 Racer's Avatar
Thats also a good weight reduction tip!!!!!
Old 01-21-2008, 02:18 PM
Falcon
Falcon's Avatar
Heck, I've had so many "Code Brown" moments in my car, a high colonic would be both unnecessary and redundant.
Quick Reply: Am I Wasting ATE BLUE ????
