Goodridge or StopTech brake lines..
Old 01-21-2008, 11:53 AM
stano
stano's Avatar
Default Goodridge or StopTech brake lines..
Any big difference between the two? I'm changing rotors and pads and thought that would be a good time to change the lines as well. I'm using Motul RBF 600
Old 01-21-2008, 12:05 PM
gkmccready
gkmccready's Avatar
Get the DRM lines. That way if you ever go to a better brake caliper all you have to do is change the fitting on the line instead of buying new lines...
Old 01-21-2008, 12:08 PM
stano
stano's Avatar
Thanks!
To Goodridge or StopTech brake lines..
Quick Reply: Goodridge or StopTech brake lines..
