Corvette has a future--but maybe a lighter, greener one
http://www.autoweek.com/apps/pbcs.dl...8/newsletter11
Less horsepower, less weight, better fuel economy, same power:weight.
Sounds like good goals to me... especially if they keep it so the motor swaps are easy.
how fast do we need to go even on the track? Less weight equals better handling and stoping which is just as important. I think eventually the engines will not be modded for street use at all. They will find a way to shut it down completely soon.
lighter/more nimble already exists...
That's not a real car fool, that's a Lotus.... A Lotus is just this side of a motorcycle...
Drop the weight to 2600 lbs or less and keep a V8, you will kill anything that Lotus makes....
I for one have been saying that this is the direction that the Corvette needs to go for more than a few years now. Make it just a bit smaller (like the last gen RX7), keep 350 hp or so, and Youaza lookout, I will be first in line....
St. Jude Donor '08
This reminds me of 1973 when they killed the muscle car at it's peak. High HP cars will come and go based on the whims of stupid politicians and those that elect them.
My Z06 gets 27 MPG on the highway with the cruise on...talk about green.
I'm just teasin' with you guys! Having said that, they are a lot of fun to toss around a track
a motorcycle...
I, for one, have been saying that this is the direction that the Corvette
first in line....
- 2007 Solstice: 2900 lb
- 1993-1995 MAZDA RX-7: 2800-2900 lb
- McLaren F1: 2850 lb
- 2007 NISSAN VERSA: 2800 lb
- 2007 Honda Fit: 2500 lb
- 2007 TOYOTA YARIS: 2400 lb
- 2007 Lotus Exige: 2100 lb
- 2008 Smart Fortwo: 1800 lb
A 2600 lb Vette (not to mention a 2100 lb one) would be quite an
achievement.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes
I have never been down the road in a lotus, but do you think most of us 'older generation' will feel as pampered in a new, lighter vette? Personally, I would love to see a smaller, lighter car. It would save tons of wear on tires and brake pads! It seems to me that the traditionally defined vette customer will be changing. I wonder if Mr. Wallace truly understands the target market?
Curb weight
achievement.
achievement.
Remember that the RX7 was a steel unibody car, and it was still 350 pounds less than a C5Z. You have to think of it more as "could you take 200 pounds out of an RX7 with lighter materials" than looking at a current Corvette and trying to take out 500 or 600 pounds.... It won't be as big a car as we have now, but it would be a heck of a lot more fun to drive....
But where will they put the golf clubs?
DOH!!!! I almost forgot they need to be able to fit two golf bags in the back of a Corvette. It is a design criteria!!!!
Kevin Howell, a Detroit area autocrosser tells a funny story about when he was doing design work on the C5.... There was a bunch of complaining and arguing about how big the rear compartment had to be to fit two golf bags.... Kevin had to go out an buy a couple of golf bags to put in the back of the mockup to make sure they could fit...
Kevin was doing a lot of design work on CATIA, modeling the entire chassis...Now there is a CATIA model of those bags in the GM archives so that they can plug them into the back of the design model and check to make sure that they fit...
Perhaps a multi-element wing could serve a dual purpose?
Mount the bags externally by creating a CF cradle that attaches at
points on the trailing edge of the roof and extends horizontally rearward
to points on the upper deck of the M-E wing.
The car will be low enough that the lift-over is insignificant. Flush
mounting fasteners will mean that aero performance is unaffected on
track days. On golf days, transportation of the bags will be more
important than downforce.
Unrealistic? Perhaps.
Larger forces are at work. The priorities of Corvette's target market
may be shifting in the next five to ten years. If so, it will be interesting
to see how the division and its competitors adapt.
Perhaps, dare I say, a younger market?
Is this going to be a Solstice with a V8 and four round tail lights?
I sure hope not... That was said to be an option in the running for the C7 and it was canned. They didn't hit any of their performance numbers, the car got heavy and they felt that it couldn't command a hefty premium in price (relative to the solsti) so the idea thankfully didn't get far.
I am impressed with the handling of the Solstice. In C/S form they are darned impressive and only a bit less so in A/S... Just need a lot more power and a lot less weight. The Solstice is a lot heavier than it needs to be. Likely the result of trying to come in at their price point... At nearly the weight of a C5Z with only a turbo four cyl engine is crazy..
