Fender liner trimming for 17x11 fitment?
Old 02-01-2008, 10:15 PM
spazegun2213
spazegun2213's Avatar
Default Fender liner trimming for 17x11 fitment?
So, i bought 17x11's thinking that they'd fit up front and rear, but alas they rub up front
So, would anyone have any guidance on where/how to cut the fender liner? Are there any places i should not cut?
Thanks!
Old 02-02-2008, 01:18 AM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
I don't get any rubbing on the fender liner but I sure do get rubbing on the lower control arms. You need to put a steering stop in place to keep the wheels from hitting the control arms since that strips the inner wheel weights off the wheel.
Bill
Old 02-02-2008, 07:24 AM
spazegun2213
Bill
where would i get one of those? is it just a collar that fits around the Rack or something?
Thanks for the tip!
Old 02-02-2008, 07:45 AM
AU N EGL
AU N EGL's Avatar
Thanks!
Is your car lowered or too low?
Old 02-02-2008, 05:16 PM
spazegun2213
its lowered but not silly low... I may try and raise it up a little, but I'll need to find out how to do that.
Old 02-02-2008, 05:31 PM
DREGSZ
DREGSZ's Avatar
I never had a problem running 17x11 w 305s all around on C4R.
Are you running 305s or 315s up front?
W 305s and rubbing, prolly too low
Old 02-02-2008, 05:43 PM
AU N EGL
AU N EGL's Avatar
I run 18x12 with 305s up front -2.2 camber with no rubbing.
My car is all the way UP on a T1 suspension which is about 1" lower then stock
Old 02-03-2008, 01:47 AM
Gray Ghost GS
"AlohaC5" Senior Member
Support Corvetteforum!
Gray Ghost GS's Avatar
I run 18x11 with 315s up front -1.6 camber with no rubbing. What type of wheels (ZR1 or Grand Sport repros?) are you using - wondering about the offset (+55?) that may be a factor if ride height is not the cause.
Old 02-03-2008, 04:44 AM
DREGSZ
DREGSZ's Avatar
It just occurred to me, which year vette are you running. My frame of reference is C4 racecars
Old 02-03-2008, 10:42 AM
spazegun2213
Sorry i probably should have posted all the info.
Car:
98 c5 on T1 springs and penske shocks (i have no idea what camber its running or height)
Wheels:
Zr-1 repos +55 17x11
Tires:
315 Hoosier rains, full tread
From what i can see the rubbing is only on the outside of the tires on both the front and the back of the fender wheels (when they are turned left and right).
Any suggestions on a height and alignment? I figure I'll have it aligned before this weekend and i hope that will solve the problem.
Old 02-03-2008, 10:46 AM
Falcon
Falcon's Avatar
Car:
Wheels:
Tires:
I run the GS offset's, not the ZR1 offset's and my only rubbing problem is on on the inside of the fender wells when the I'm at full right or full left.
Old 02-03-2008, 10:58 PM
spazegun2213
I think the +50 is the GS offset so I'd think +55 would not be that bad. Now I'm sure its the height thats the problem with my car. So time to raise it up a little.
To Fender liner trimming for 17x11 fitment?
Quick Reply: Fender liner trimming for 17x11 fitment?
