Mixing R6 and R3SO5 Slicks
Mysteriously a rim leak appeared in the left rear of my Hoosier R5. The tire guys couldn't seal it. (Ideas for fixing this are welcome!) So I mounted a Hoosier R3SO5 of the same size instead. Traction, temp, wear, etc parameters are the same. Any hazard running these together?
Somebody get rid of that damn ad to the right
Anyone else who has fixed a slow rim leak please chime in. The wheel rim appears fine, the area of the tire bead where the air is sealed off has marks like a screen door got caught between the tire and the wheel.
I am trying to fix it by sanding irregular surfaces, cutting leftover molding rubber off, and smoothing it with toluene. The area has dried and looks improved.
