C4 vs C5 wheel offset
I've heard conflicting opinions on this and searching the forum didn't help much.....
The question is, as long as a set of wheels clear everything on a C5 does that mean they will always work on a C4 also?
The reason for the question is I'm changing my track only 94 to CCWs this year and I'm having a hard time finding used 17s so I'm thinking of going to 18s since they seem to be more readily available. Specifically I'm thinking 18 X 11 in front and 18 X 12 in back. I want to go to at least 11s at all four corners.
Also, when measuring offset, is the proper method to put a straight edge across the back of the wheel on the outer lip and measure the distance to the flat mounting surface at the hub face?
I don't really want to spend the money on new ones since they are for the track only but it's looking like that's what I'll have to do.
Thanks.
Thanks.
TTT
I want to read the answer on this one as well. The 18" scrubs are becoming much more plentiful as well. I wonder if any of the Pirelli Grand Am 18" scrubs will hit the market soon.
I'm running 18x10.5 C5 Z06 rear wheels on all 4 corners of my C4. They fit perfectly and don't stick out at all. C4's GENERALLY have more wheel well space than a C5, especially if they aren't slammed. So, I'm going to guess they will. I also run 17x11 50mm offset on all 4 corners, and they work well.
"AlohaC5" Senior Member
I sold my stock C5 wheels to a C4 owner and they worked great. He sent me pics - looked real sharp! However, once you go wider than stock Z06 wheels - all bets are off. You'll then need to verify fitment, etc.
315/30R18 Falken Azenis. I run them for my local street tire auto-x class.
More pics here: http://mowhineracing.com/ch18.html
I thought that any wheel that fit on a c-5 would work on a c-4 and I borrowed a set of 18x12 ccw's from a friend to use up some 335 scrubs that i had. When on the car they hit the trailing arms. I put on 1/2 in. spacers and seemed to have enough clearence but after a 20 minute session the trailing arm mount cut a 1/4 in. groove in both tires. Probly would have worked with 315's but don't know. I normally run 17x12 ccw's but they stick out of the wheel wells further than the c-5 wheels.
That is a great question. I have a stock short block that needs freshening up and my heads are at Lloyd Elliots being fixed/ported. I need to take the bottom end I have to the machine shop and figure out what it needs before doing anything else.
Early C4 wheel offsets are different than later C4 wheel offsets so be careful. You can search these forums for the specs but I recall the early ones are 32mm and the later are 50mm with the exception of the ZR1 which I think was also 36mm.
