Help with Coil Overs
I just got my van steel offset t arms and coil over kit. I am wondering how do you tell a double adj coil over from a single? Would there be two *****, one for rebound and one for compression on the QA1 double? There site is not clear, no pretty pictures of both types that make it obvious..... Or does one **** do it all, they dont give ANY info with the kit, they know what the **** does, but have not told me I realize it adjusts rebound or compression- or both??
Thanks,
Denis
Thanks,
Denis
Premium Supporting Vendor
The single adjustable shocks have 1 **** that adjust rebound and compression simultaneously. The double adjustables have 2 *****. One controlling rebound and 1 controlling compression. The single adjustable has 12 different adjustments to make and are recommended for street drivers. The double adjustables have 576 different adjustments and are recommended for track driving to dial the car in better.
Thanks the parts look VERY high quality and complete. Except info
There should have been a 4 page instruction sheet on it all. Plus another document on how to do a quick alignment. Unfortunetly I am out of town and won't be able to e-mail you the instruction document until Monday.
