DRM four point bar
DRM four point bar
who here has used the C4 DRM bar? thinking about purchasing..... how does it mount, i'm looking to weld to the frame rails thanks
Sure, here you go:
Be careful, though, you had mentioned in a PM that you were thinking of building off of it in the future for a full cage. The reason I had to cut mine was because the rear bars have a bend at the bottom, and some organizations (NASA at least) require the rear bars to be straight.
You might want to call Randy at DRM and see if they still have the bend.
