How Is Your C6ZO6 Holding Up ??????
Old 02-19-2008, 12:33 PM
  #41
whosurdaddy
whosurdaddy's Avatar
After two seasons in my 2006 I rarely get more than 270* oil temps during the summer. I keep the oil fresh and don't feel the need to use every single RPM - its no fun to blow away a poor little Porsche in the straights, I'd rather do it through corners where its saying something.
Also, I keeping an eye on the chassis per my earlier comments on the aluminum frame - plus I've been considering replacing the stock bushings with something better.
How much time does it take a mechanic to do all 4 corners plus the sway bars? Is there a downside to doing this on a mixed track/street use car? Anybody done it yet?
Old 02-19-2008, 01:13 PM
  #42
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
^ I have VB&P poly bushings in my C5Z. The ride is firmer and even harsh over bumps. Also there is some squeeking at times. It is the nature of the beast. I'm installing Koni FSD schocks to bring back some of the street manners.
Old 02-19-2008, 01:39 PM
  #43
95jersey
95jersey's Avatar
Even a harder rubber would be perfect (do you hear us LG/PDFAT/VBP) I used poly in my C5Z all the way around and no matter what, will never put them on my C6Z. I lucked out and found someone who understood the benefit of poly, when I sold my 01Z, but I spent several sleepless nights worrying who was going to buy my squeeking nightmare.
Old 02-19-2008, 01:40 PM
  #44
Cobra4B
Cobra4B's Avatar
^ Haha... mine only sqeeks from the right front, and only at odd times. It's not constant.
Old 02-19-2008, 02:09 PM
  #45
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Originally Posted by xsiveone
I'm still curious about the aluminum frame. Why didn't Corvette Racing use it for the C6.R? Also, why did the C6.R use coil overs while they still put tranverse leaf springs on the production car? I'm not saying that the transverse leaf springs are bad by any means, but if it's so good, why don't they use it on their race car?
I'm still baffled by the padlet thing. I think that was a really poor move by GM.
Did LG start with Z06's for his WC cars? I would think that he'd use a C6 for it because he totally rebuilt the car anyway.
LG WC cars are C5's with a changed wheelbase, new cradle. They were not allow to use aluminum frames in the C6R.
Look on the wbe site of LGM and pictures aer or were their.
Cage for a aluminum frame is a lot more than a weld in cage.
Old 02-19-2008, 04:02 PM
  #46
XPC5R
XPC5R's Avatar
Consider the GM T1 control arms for the C5 (or maybe C6 now that they are the car to have). They have rubber bushings like stock, but higher durometer (stiffer). So better feel, with no additional noise.
Old 02-19-2008, 05:10 PM
  #47
whosurdaddy
Do you have to buy the whole T1 suspension package or are they available seperately?
Old 02-19-2008, 05:33 PM
  #48
John Shiels
you have to buy the control arms which are 200+ each for a C5. Bushings in OEM are fused / bonded in the hole.
Old 02-19-2008, 09:46 PM
  #49
Timz06
Timz06's Avatar
C6z06 totally stock powertrain and suspension is more than adequate for any DE type use. You don't need any of the junk listed in this thread. As mentioned the problem areas are brake pads and rotors. This coupled with more expensive wheels and tires will make a new z06 a bit more expensive to run than the c5.
Tim
Old 02-19-2008, 09:51 PM
  #50
John Shiels
Tim
all depends on how hard you run it.
Old 02-20-2008, 07:51 AM
  #51
whosurdaddy
I agree. The general didn't develop a race car for $70k (or even $100k on the ZR1). They developed a street car that kicks a#$ in light to moderate track use. The shortcommings related to the allpresent street/track compromise start popping up with heavy & hard use.
Old 02-20-2008, 05:55 PM
  #52
Timz06
Timz06's Avatar
I am talking about DE type use 20-30 minutes sessions. If you want to find out bring it on
Tim
Old 02-20-2008, 06:35 PM
  #53
John Shiels
Tim
Love to drop by Pocono
Old 02-20-2008, 07:27 PM
  #54
Timz06
Timz06's Avatar
Sorry, I don't do Nascar , I'll be at the NCM event at VIR with the new car.
Tim
Old 02-20-2008, 08:14 PM
  #55
whosurdaddy
Tim
Cool. If you've been on VIR Full before, what are your laptimes?
Old 02-20-2008, 08:20 PM
  #56
John Shiels
Tim
far from NASCAR
Old 02-20-2008, 09:34 PM
  #57
Timz06
Timz06's Avatar
In my stock 01 385hp z06 with V710's I ran 2:10. I have not run this car but I would guess 2:05 or less
Tim
To How Is Your C6ZO6 Holding Up ??????
Old 02-20-2008, 09:44 PM
  #58
John Shiels
nice times
Old 02-20-2008, 10:33 PM
  #59
whosurdaddy
Tim
In 4 trips to VIR, I've not gotten below 2:13's on street rubber but have still melted the steering linkage boots and squished the front left control arm bushings. I am surprised that you did not run into similar issues in your C5 (I did).
I would like to get rid of the slop and lack of connectedness in my C6Z. I think some of the suggestions in this thread have the potential of doing this.
By the way, smokin' laptimes. Stock Z's rarely find their way into the 2:10's.
Old 02-21-2008, 01:34 AM
  #60
Dirty Howie
Dirty Howie's Avatar
Tim
I'm going to ignore the other guys .....
As this is what I want to hear
DH
Quick Reply: How Is Your C6ZO6 Holding Up ??????
