Drawbacks w/ Sparco seat?
I just finished putting my seat in the car and wanted to ask those that have done if there are any drawbacks after installing it with the airbag and seatbelts being unplugged? I guess what I am getting at is it doesn't throw some crazy code that send the car into limp mode or something?
It's a C6 BTW.
It's a C6 BTW.
1 Post
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
It's a C6 BTW.
It's a C6 BTW.
As you have probably already noticed, a couple of things will happen to your car when you remove the drivers seat. First, the airbag light will come on. That is because you took out two of the airbags from the system and the computer is telling you that there is a problem (they're missing).
The second thing that happens is that your telescoping wheel (if equipped) will not work any longer. That is about it for the drama.
The Pfadt wiring harness for the C6 has two components to it. One is a harness that allows you to keep the memory seat module - normally attached to the bottom of the drivers seat - in the car and functional. For overly complicated GM reasons, that box has to be in there for the tele wheel to work.
The second component of our kit is a small harness that turns off your airbag light. It does nothing more than that. The SRS (airbag system) is very complicated and computer controlled. Pfadt makes no claims as to the functionality of the system after removing the seat/airbags. The mechanical components of the safety system are compromised and the system will not work as designed. Our kit will turn off the light in the dash. It is up to the driver to determine the safety of the car and the risks associated with removing the seat.
The harness is not currently on our website because our website is undergoing a major revision. The harness are available, just call and we can get on shipped out to you. The cost on the harness is $100.
Please feel free to call if you have any questions.
thanks,
Aaron
Thanks for the info Aaron. Two more questions for you...
1) Do either component of the harness create any issues when re-installing the stock seat? I plan on using race seats only on track days, then swapping the stock seat back in for normal use.
2) Just to be clear, this works for all flavors of C6? I have a 2LZ Z06...
Thx
jb
Thx
jb
1 Post
St. Jude Donor '08
Thx
jb
Thx
jb
2) It works on all C6s up to this point. Our Z is a 2LZ also and it works great.
-Aaron
Steve,
thanks,
Aaron
thanks,
Aaron
If yes, I'll buy one today!
1 Post
St. Jude Donor '08
Yep, it's that simple.
The one caveat is that if you are removing both seats, the passenger side airbag stuff is nearly impossible to fool. The seat has a computer in it that tells the car whether a passenger is present etc... The consequence is that the airbag light will stay on if you pull both seats. The tele wheel and everything else will still work though.
-Aaron
-Aaron
If I knew my thread might generate some sales for you Aaron, I would have asked for a discount when I ordered my seat mount from you.
BTW, where can I find info. on your new shocks (non-coilover) for the C6? Don't see them listed on the website.
When I put my race seat in a few years ago I didn't know it would disable the Wheel. Now I don't even know if it is in or out. Anyone have a measurement so I can check mine? Might make getting in and out easier with my Kirkey. I guess it would be good with a quick release wheel I want to put in also? Thanks!
