C5 Spring rates and antisway bar sizes - 97-04
I am looking for a brakedown of OE spring rates/bar sizes on C5s from 1997-2004 for base models, Z51 and ZO6. I know they varied over the production run.
Any reference/info greatly appreciated.
C5 SWAY BAR COMPARISON
Bars Front Dia. Rear Dia. Thickness
Base / FE1 23 mm 19.1 mm
Z51 / FE3 - '97-'99 25.4 mm 21.7 mm
Z51 / FE3 - '00-'04 28.6 mm 23.6 mm
note rear same as Z06 rear, and both updated from earlier Z51 bars.
Z06 / FE4 30.0 mm 23.6 mm
Fantastic for good street driving, and good for autocrossing.
ADDCO/BMR 31? mm 21? mm
Hotchkis 31.75 mm 25.4 mm
Don't know the spring rates. Sorry.
Here are some accumulated data from over the years for model years 00to 2004:
Bars in mm
Suspension type Front thickness-- Rear thickness
Base 23.1 3.81 19.1 2.0
FE-3 28.6 4.15 23.6 3.0
FE-4 (Z06) 30.0 4.5 23.6 3.5
T-1 38.4 6.35 27.5 6.35
Spring rates have been reported all over the map, but this is what I have:
Base 440 577
FE-3 525 634
FE-4 (Z06) 525 714
T-1 approx 700 900
These are the rates of the springs, NOT the effective rate at the wheel. Some people have exhibited doubt that the rear Vette springs are higher rates than the front springs, but this is the way it is because of the geometery of the suspension design.
I hope this is helpful
Jim
Bars in mm
Base 440 577
FE-3 525 634
FE-4 (Z06) 525 714
T-1 approx 700 900
Jim
This is all really useful - data does seem to be all over the map...
looking for some takeoff base model sways and springs...
I "heard" but have not seen a car with it yet, or any production proof, that the base late 2003 and 2004 came with the same size bars as 97-99 Z51.
All second hand info, mostly collected from the forums here.
Swaybars:
Springs:
Sorry I don't have more C5 spring data.
Swaybars:
- C5 Base Suspension: 23 mm-front / 19.1 mm-rear / 3.81mm/2.0mm thickness
- C5 Z51 (97-99): 25.4 mm-front / 21.7 mm-rear
- C5 Z51 (00-04): 28.6 mm-front / 23.6 mm-rear / 4.15mm/3mm thickness
- C5 Z06: 30.0 mm-front / 23.6 mm-rear / 4.5mm/3.5mm thickness
- C6 Base: ?? mm-front / 22.0 mm (7/8")-rear
- C6 Z51: 31 mm-front / 25.4 mm (1")-rear
- C6 Z06: 31 mm-front / 28.8 mm-rear
- C5 Hotchkis: 31.75 mm-front / 25.4 mm-rear / 4mm/4mm thickness
- C5/C6 Addco: 32 mm-front / 25.4 mm-rear
- C5/C6 Addco: 35 mm-front / 25.4 mm-rear
- C5 Pfadt (Adjustables): 32 mm-front / 26 mm-rear http://www.pfadtracing.com/
- C5 Pfadt (Adjustables): 35 mm-front / 28.5 mm-rear (Pfatty)
- C5 T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear / 6.35/6.35 thickness
- C6 T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear / 6mm/?? thick
Springs:
- C5 Z06: 526# Front, 714# Rear
- C6 Z06: 531# Front, 782# Rear
- C6 Z51: 526# Front, 645# Rear
- T1 (C6): 582# Front, 850# Rear
- C6 Base: 420# Front, 657# Rear (VBP: 400-420 F / 600-620 R)
- T1 (C5): 582# Front, 793# Rear
- Pfadt Coil-overs: 425# Front, 575# Rear (Remember: Wheel rates!)
- Hyperco HPS (Street): 565# Front (12405HPS), #765 Rear (12406HPS)
- Hyperco HPT (Track/Solo): 625# Front (12407HPT), #850 Rear (12408HPT)
- VBP Sport 990# Front, 650# Rear
- VBP Extreme 1050# Front, 855# Rear
here are some part numbers I found
GM OEM Z06 Front Swaybar: 10419094
GM OEM Z06 Front swaybar bushings: 10419095 (2 needed)
GM OEM Z51 Front swaybar: 10424741
GM OEM Z51 Front swaybar bushings: 10424742 (2 needed)
GM OEM Z06/Z51 Rear Swaybar: 10424743
GM OEM Z06/Z51 Rear swaybar bushings 10431951 (2 needed)
GM OEM 2002+ Z06 Aluminum endlinks: 10435298
This link tells how to swap the swaybar:
http://www.ls1howto.com/index.php?article=16
Z06 Front spring: 22178729
Z06 Rear spring: 22188038
Z51 Front spring: 22178729 (note: same as Z06)
Z51 Rear spring: 22179020
Base Front Spring: 22178728
Base Rear Spring: 22179019
How to swap the springs:
http://www.ls1howto.com/index.php?article=20
Here is a link to the NCM. YOu can find most of what you are looking for except spring rates.
http://www.corvettemuseum.com/specs/2001/specs.htm
I usually go here to find specs but they don't have the spring rates for the '01
http://www.corvetteactioncenter.com/...2001specs.html
