Harnesses??
Harnesses??
I am shopping around for harnesses for the track car I am building, and I am looking for some advice. My plan is to use these belts with a HANS device.
1. 5 or 6 point? I am using a Kirkey Intermediate road race seat and a more upright type seating position.
2. Pull up or pull down? I would like to make sure I can tighten the belts myself. The belts will be coming through the Kirkey seat.
3. Camlock or latch and link? I have a latch and link now, and it can sometimes be hard to latch because I can't see it with my helmet on. Are the camlocks easier to latch?
4. Brand. I have budgeted $500 for a set, but I am also running a little above my budget right now. I have heard all the sayings about buy a $10 helmet for your $10 head. However, does anyone have real experience to say one brand is better than another? What makes it better? Basically, will a properly installed and maintained G-force harness work as well as a Simpson/Impact/Schroth?
Thanks for the input.
Ken
Ken
Vetteless
St. Jude Donor '09
Hey Ken,
I don't have a ton of experience, but here's what I do know:
1) The 6-point I have in my car now is more comfortable on the ol' jewels than the 5-point I had in my old car.
2) I've always used pull-up, but most belts you can thread either way, so it's probably not a huge deal if you pick one and then change your mind.
3) Camlock is definitely better than latch-type.
4) The 6-point Schroth I use now is specifically designed (and only legal) for use with a HANS setup. The shoulder belts are 2" rather than 3" to better fit in the tracks on the sides of the HANS. Compared to the other brands of belts I've seen/used, the Schroth hardware is very nice and I feel like it was well worth the little extra $$. I think I spent about $300 for one belt.
Good luck!
Good luck!
my .02
1. 6-point, the jewels are important
2. My first harness had pull up lap belts and I had trouble with it because I have to pull it so far (i'm skinny). There just wasn't enough room beside the seat. new one is pull down and problem solved. Shoulder belts are always pull down unless someone else is going to be standing over you strapping you in (think formula car)
3. both of mine have been camlocks. I've used latch-link in go-cart and stuff like that, and the camlock is well for a few extra dollars.
4. My first set was made by Crow. Nice enough and worked. I've currently got a Sparco harness made by Scroth and the quality is much better. The difference is in the detail, most importantly the sub-belts are separated by a few inches instead of going together to clip into the camlock (see comment #1)
Thanks for the replies. I think my mind is settled on a 6-point and camlock. I don't have to worry about being too skinny (I'm short for my weight) so I'm not sure about the pull up/pull down. I may look for sets that allow you to thread them either way.
Now, the big decision is the price point. I am going to shop around and see where I can find the best deals.
Thanks again.
Ken
Thanks again.
Ken
I have G-Force pull up, 6 point, Camlock and am very happy with them, they are fully certified and they are priced right. I have used both pull/up and pull/down in vettes and the pull/ups seem to work better in the tight quarters of the vette. JD
Thanks again.
Ken
Thanks again.
Ken
One comment about Camlock versus Latch and Link.
I have actually seen a demonstration where they put a person upside down in each type of harness. The Latch and Link is nearly as easy to open when your full body weight is on it. The Camlock, however, can tend to bind and be very difficult to get open with your full body weight on it.
Just something to think about. How long do you want to be hanging upside down in your harness, with your car on fire???
DaveZ.
DaveZ.
Most Car clubs will no longer allow this type of seat & harness set up. Shoulder harness must pass though the seat. PCA & BMW clubs now require seats that were designed for harnesses. Modified stock seats will not pass tech.
Not a good option. The likely hood of your body sliding though the harness under hard stop or impact is very high with this set up
If you are using the stock seats then a sternum strap is required. Most companies sell shoulder straps with these to replace the straps that come with the harness. Or, it can be sewn on by the manufacture. Basically this is an additional latch that goes between the shoulder straps across your chest to keep the straps from sliding off of your soulder. HIGHLY recommended for stock seats at high speed events.
This is what I am using now. It works well with the B-K lap mounting points. This setup will not work well with a HANS or R3 because shoulder straps do not come across the shoulder close enough to the neck to hold the device in place correctly. That is why I am going to a race seat. Plus more and more clubs want the passthroughs. Also when using a sternum strap make sure that it is located properly so as not to choke you in the event of a crash.
CF Senior Member
Although this may not pass tech with certain organizations, I've seen several other more experienced C6 racers do it this way. Also, I may change the location of the sub strap (so it comes through the lower seat back behind me...then under my butt to the cam-lock). I realize it isn't ideal but it's a vast improvement over the factory seat belt. I'll change seats in the future but for now this works pretty well.
I use one of these with an Ultrashield Road Race Seat and unless I close the door as I get in the car I can't reach the handle to close the door..... Being planted in place will go a long way to not being tired at the end of the day. You won't be hanging on to the steering wheel and planting your left foot on the dead pedal.
