Big brakes and 17
Big brakes and 17
What is the best brakes you can put on a C5 and still use 17" rims?
Thanks for the replys. I am running HRE and Fiske wheels with long studs so it looks like a call to LG is coming
OEM GS front wheels are 56mm offset and OEM Z06 front wheels are 54mm. Your aftermarket wheels must have huge offset to require a 5/8" spacer.
You can bet on needing over a 1/2" spacer to fit a Fikse wheel over the LG Wilwood kit. Fikse wheels are not wide caliper friendly. I test fitted a FM5 and an Aro over the Wilwood with the narrowed outside body and it needed a 7/16" spacer. The LG Wilwood caliper will need about .25" more then that.
George
George
Location: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
With a 1/2 spacer can you utilize stock wheel studs or do you need longer ones?
