Dodge tow vehicle transmission Dead
Well after 109,000 miles I was changing the oil, filter and tightening the bands. Found a piece of metal. I described it to a tranny guy he said it was band clamp on a over-drive unit. I was hoping to get 125-150 on it I always serviced it as require every 30,000
Sorry to hear about your tranny problems John. There are two bands in this unit. One for 3rd gear and one for low and reverse. Both located in the pan area. What we see in your case is a broke snapring on the OD clucth in the tailhousing. If you still have OD and caught it soon enough. You can simply pull the tailhousing off and replace the snapring. Feel free to PM with any questions.
Troy
Troy
me doing the work is not an option. Tranny still runs good with nothing wrong except split second slip only when cold. Tranny place wants 2,000 for rebuild. Piece I found was size of a match from a book of matches. Tranny guy will probably not do what you suggest Troy. probably wants to do the whole thing I imagine. I didn't check OD but will tonight I was happy to get back home.
I was trying to look at a upgraded tranny on Turbodieselregistry.com. May be throw a box on it for some more zip. I never did it before figuring I would toast the tranny. I need an exhaust also so I might go bigger there also. Looking at web sites I haven't found a listing for a complete upgraded tranny. I called Jannetry Racing in Conn. and left a message.
Don't want to really wreck it more and have the case or more hardware be destroyed. If I upgrade I guess this over-drive pump band is still the same?
Thanks!
Thanks!
John,
PM me the year and last 8 of your VIN(if you feel comfortable with that)....I can talk to the guys in the trans lab and see what they think...pics of the part would help too.
Too bad you weren't closer to Michigan, all of them do side work and are extremely reasonable. They have all the specialty tools and can do the work in their sleep.
Couple of guys at work have near 700hp setups using the Gear Vendors units and really like them.
Sorry to hear all that. My 2003 Dodge 3500 has 152K on it and no real issues. There was some cheap electronic part that crapped out a long time ago that wouldn't let it drop to 1st gear, but I fixed that and have had no real problems. It's never been ultra smooth, but it shifts so I'm not concerned. knock, knock
I'd say that about 50K+ of those miles are actually towing. ...somewhere between 20-27K GVW!
I had a solenoid go bad at 10,000 which messed up shifting. I do a bunch of towing at work 10,000+ and they truck loaded at times. Still can't decide if I should go for a super tranny for 3600 then pump the power up soon. I love the truck and motor.
I'm using a VanAaken power box on mine, which supposedly boosted the power to nearly 400HP and over 850 lb-ft of torque! It tows like a dream!
Zero to 60 times dropped from 11.2 seconds to 8.5 with it!!!! That's not revving it or power braking before the launch or anything. That's just me clicking a stopwatch and romping the gas! Great stuff!
Those diesels are nuts.
I watched diesel drag racing the other day on Speed.
Great idea, poor execution. When they spool up you can't see anything and the cloud and drifts over to the stands would choke anyone out of the track
Cire
