Warning! Contact paper for paint protection.......
***Warning to anyone using contact paper to protect their paint***
Can it be buffed out?
At the track on Monday, a piece of clear adhesive contact paper which I use on my hood to prevent rock/rubber marks came off at ~140mph. It fluttered a little before it flew off, and where it slapped the paint, the clearcoat is damaged. I can BARELY feel it with my fingernail.......and in most places, cannot feel it at all.
Will something like a Porter Cable 7424 Random take it out? Or should I just take it somewhere and let them use a high-speed rotary?
Are you sure it isn't the adhesive?
I have used it for two seasons now. To date I have had no damage. Sometimes I have to use WD40 or adhesive remover to clean off the adhesive.
I think that, in this small section, the corner of the contact paper that peeled up may have gotten contaminated on the adhesive side with some fine grit dirt in VIR's nice sandy windy pit area. It's in the clearcoat
That stinks. It was probably cooler temps? It doesn't stick too good when cold. Most likely it can be rubbed out. Just find a good detailer or painter.
Good luck.
Good luck.
Kind of hard to tell just from a picture, but if it's not too deep into the clear coat you can wet sand it until it's smooth. Then use some rubbing compound and a high-speed buffer (like a Makita) to buff it back out. I would also use some swirl mark remover and wax afterwards. It will look like new.
You may have to go to an automotive paint store to get the proper sandpaper. I recommend 2000 grit. Good luck!
Thanks guys! I have a detailer coming by the house tomorrow, should know something then.
Just a recommendation....you NEED to tape the exposed edges of the contact paper with race or painters tape. This will prevent this from happening in the future. If you secure all of the edges with generous amounts of tape, it will hold and not flap around.
I also had fresh wax under the paper, which hurt adhesion, but greatly simplifies left-over-adhesive removal.
You might try using a cleaning clay. The clay does take out small particles that are embedded in the paint and then polish.
I have the same problem with my front. I have a bra but there is a hole where the emblem is, so I tried covering it with contact paper, but it shredded and bra went back to slapping. It all has buffed out so far. Good luck with it.
Man Chris My car looks better then that and I have never used anything.
OH wait, I did put on new body parts from some strange reason
Wonder if a good clay bar rubbing and zaino or redix or rejected or rejax what ever it is called, would to the trick?
It took a high-speed rotary buffer, along with a very small amount of medium-grit polish, followed by some fine-grit, followed by a very fine finishing polish using a random orbital. 99% of it came out.
After:
Yup. I actually had all of the leading edges taped. I made the mistake of not taping the trailing edges thoroughly. A tear in the paper started in the trailing edge, then the damage occurred as the paper lifted at the trailing edge, then fluttered and ripped all the way to the leading edge.
Glad you made out ok--I'll be more careful w/ my next outing.
