rear wings and rear spoilers
Hi guys,
On high speed tracks running C5's have you guys noticed real benefits from rear spoilers and rear wings. For those who started with rear spoilers and changed to rear wings I'd like to hear from you especially. Guys with experience at willow springs big track what about benefits on 8/9 complex?
Thanks!!
Thanks!!
The proper products work great. Stuff on my car works real good but don't expect a huge difference by dropping a smaller splitter with no under-tray or a spoiler or junk wing. If you are getting good down-force expect to reconfigure your entire suspension. First few times I drove my car it felt like it was getting squashed to the ground. Like HP the feeling leaves and seems normal after some time. Hood and vented wheelwells also help. Air coming in the front of my car vs. a bottom breather also helps.
aerodynamic devices are not bolt on and go. They do take some tweeking to get them right.
A corvettes proper rake is the most beneficial to aerodynamics. Plus the right suspension, ride height and alignment.
Done right it is worth a lot of HP. I could have dumped more HP but HP doesn't help under braking or cornering. There are enough people who know what to do and it can be pay, bolt on and go!
Falcon has a 3" lexon rear spoiler. Pointed up at 45*
He noticed that on high speed esses, VIR up hill esses, the rear of the car sticks better.
I noticed that also with my 1" spoiler
Rear spoilers will produce downforce. They will help at high speed. Used them for years on the Nascar cup and tour cars. Remember that the extra force is loaded into the car behind the rear wheels, too much rear downforce can cause the front end to understeer (push for you stock car guys) so, balance front to rear should be considered also. No easy answer, you must test and see what works for you, the car, and the track..
There are some good and understandable books on aero which is good reading. Sam as 3-4 gallons of gas and you always have it unlike gas.
