Oil Coolers
Oil Coolers
I do about 6 HPDE weekends a year currently and am looking to get an oil cooler for my 02 Z06. I am undecided whether to do a combo unit like the Dewitts or go with a stand alone (like DRM) and keep the stock radiator.
I'd like to hear some opinions, thoughts, and experiences with both types.
Thanks,
cj
Thanks,
cj
Tom, if I quote from a story/post I believe you wrote, you recommend a separate oil cooler for road racing as it lowers oil temps relative to a combined.
PS. I have your radiator and a separate oil cooler in my car! Coolant and oil temps went down over 20 degrees from the OEM set up. Thanks
I was running about 280 deg on an August day at VIR. Added the DRM kit external cooler and have not seen above 240 even on a 100 degree day last summer. Running stock radiator and the cooler is mounted low in front of radiator. H20 temps are fine even in August. I recommend the DRM kit with a thermostat.
cj
Location: If you don't weigh in you don't wrestle Road America
The stand alone kits are nice because they are easeir to install and it will cool the oil down the most. However the stock radiators are not up to the task for DE's. You may only do 6 a year but how many years are you planning on holding on to the car? If it's only one or two then go ahead and get the stand alone, if you are planning on sticking with the car and possibly adding power (heads/cam or more cubes etc) then you should really look into a combo. The combo will give you better cooling for more power and it will also give you an oil cooler. If you drive the car on the street your oil temps will come up sooner also because the coolant will help heat up you oil when the oil is cold.
I've had one of the cheap OEM radiators split a tank on me on track and when both RH tires get coolant on them it's no fun.
The fact that the OEM radiator has plastic side tanks and an aluminum core is not the best for road racing they heat up and cool at different rates and the radiator can fail. My tank seperated and my weekend was done.
I would look at it this way if you are happy with doing 6 events a year and don't plan on any extra power in the future then just buy the stand alone, but if you think you will start doing more events and adding power then go with the combo and play it safe.
The DRM kit is not that difficult to install. It took me about 4 hours on the floor of the garage with jack stands. Having access to a lift would have cut that time by at least an hour or more. Instructions with the kit were fine and detailed enough that any one reasonably mechanically inclined could do the install.
My Ron Davis dropped my oil temps on my stock C5 from 300+ down to 270's on a warm day and in the 280"s on Hot Texas days plus keeps the water under 200 on road trips.
I see no reason why running a combo external cooler plus EOC radiator would be an issue, in fact, I'm thinking about adding a cooler inside the front bumper when I plumb in a accumulator. Just be sure if running the car on the street, add an oil thermostat bypass so the oil will warm up on cool days.
Good luck on keeping it cool
I got the in radiator cooler from DeWitt, and I am happy with it so far. I have so many additional coolers that it was nice to have one inside the radiator for use, because of space concerns.
Former Vendor
PM me your e-mail, and I will send over some info on our Oil cooler setup!!! I built a couple kits this past weekend.
Randy
www.dougrippie.com
Randy
www.dougrippie.com
cj
Randy
www.dougrippie.com
Randy
www.dougrippie.com
scottperkins27@yahoo.com
Thanks.
Former Vendor
Randy
