C6 07" Z-06 Tie Down Help
Looking for the suggestions where and how to tie down Z-06 to open trailer?? Trailer is equip with d-rings and side lugs.
You should be able to get the hooks at any trailer supply company. After tied down, remember to set parking brake and leave in neutral so the car doesn't rock on the trans gears.
Aaron
Use the factory frame holes with T-Hooks just like the haulers use on the semi's. I cross the straps front and rear and it never moves.
Aaron
Aaron
C5 XTC
Photo of rear
Note:
Once you have the perfect distance set up for the front, many ppl use a chain. t-hook on the car side and other hook with clasp on the tie down side D-ring.
Then only the 5000 lb ratchets on the back.
Note:
This is my preference and it makes sense to me!
