WTB lexan wind shield for the c4
Go to www.fivestarbodies.com go to online catalog then to chevrolet then you will see corvette. They have windshields and rear windows.
Try a local auto glass shop. That is where I found mine and it was MUCH cheaper. May have to call around to several. I paid $287 installed. Weight savings was: glass windshield (30.5 lbs), 3/16" Lexan (14.0 lbs), riveted & glued.
I do not recommend making the change. My car is dedicated to racing and I am going back to glass. Lexan is light, but scratches far too easily after a few events and will have to be replaced again. One time driving into the sun with scratched Lexan and you will know why. The only solution I know of is tear-offs like NASCAR uses, but they drive the cost up.
Ed
Ed
Melrose T tops has the front. Buy the tear off material. It was cheep for a roll, a pain to apply but after it scratches pull it off and reapply. The stuff I used was also from melrose, it was not formed for the windshield so I used two strips each covered a side of the windshield. It covers all but the last few inches on the outside bottom because it is too curved.
Mat
Mat
Third vote for Melrose...got my front there also. $375 shipped. It needed minor modification to fit well. Install took about 2 hours, not including removal of the old glass.
It's installed and ready to go. I suggest painting the borders before installing it, makes it look much better. Just mask it well, I had a little paint bleed through the paper. Luckily it's up where the mirror will block it so no worries.
