Where to get stock C5 front hubs
I broke one of my front hubs again racing at Buttonwillow this weekend.
I figured I am going to replace them both and buy a couple of extra ones. I need to stay with the stock Timken units due to class rules.
I did a Google/Froogle search and came up with this supplier at $139.95.
http://www.ioffer.com/i/Corvette-C5-...aring-30879841
Does anyone else have a recommended source?
Thanks a million!
Thanks a million!
That's a heckuva price.
Gene Culley at GM Parts House has them for ~$258 and that's about $100 off of list.
Oli, I just looked at the ad in your post. It says:
"Brand new Original Equipment Style (OES) direct fit Front Wheel Hub Bearing Assembly."
Notice the word "style" in the ad. Those obviously aren't OEM hubs, if that makes a difference to you.
I assumed that they are Timkens on an overstock close-out sale at iOffer... I could be wrong.
I just ordered some and I will let you guys know how they work out....
You can get genuine Timken bearing assemblies (the OEM units) from Autozone. The last one I bought (last year) was $140.00, if I recall correctly.
Frank Gonzalez
Frank Gonzalez
Vetteless
St. Jude Donor '09
Cruise-In VI Veteran
From what I have heard if you run any kind of oversize sticky tire these bearings tend to go a lot faster. Is this true? If so I am probably going to start adding that as a part to include in my stuff to bring to the track. Just what I need...more stuff to bring. I do believe that Advance Auto has the Timkens also for about the same price.
Bob
Bob
Received 8,928 Likes
I wonder about how long mine may last also. Last year the right front and left rear bearings were replaced under GMPP. That was during the 5th season running the car. My 97 went 6 seasons and had all 4 replaced at the same time. So I may be looking at replacing the other two this year. So far I have never cracked a hub.
Bill
Bill
Bob
Bob
1 Post
Cruise-In II Veteran
I saw the new roller bearing C5/C6 versions at VanSteel last week, and man are they beefy. I will be stocking them as a product, and the challenge is to get them SCCA, NCCC, etc approved. They will not offer any competitive advantage, and since they are about 2 pounds heavier might be slightly the opposite, but the improved durability should be a big cost savings over a season. I think the retail on the new US made tapered roller bearings will be $273.99 and that is a form-fit-function replacement with the ABS encoder. They are to start shipping in 5 weeks.
Bill
Bill
My statistics show I break them twice a season even with some preemptive replacement. I am trying to figure out how many track/race days they are good for.
Some tracks are tougher on the hubs than others. Willow Springs International and Cal Speedway are not hard on them at all. Streets of Willow Springs somewhat rougher. Buttonwillow raceway has a lot of curbing and the fast line around the track involves running up the candy cane curbing to straighten out the corner, especially on Cotton Corners. The roughest spot though is the esses. The fast line through there when someone is on your but is to clip the edges of the curbing at about 112 MPH! That has to be hard on the hubs, but it is fast.
Damn Oli, again?
Last time I replaced mine I did the autozone thing. Seems to have worked out well so far (i think I paid 130 for the rears and 160 for the fronts, or maybe it was the other way around?)
