Solo II - Street Prepared - Brake Upgrade Question
I know I can upgrade my JL9 (12" Rotors) to the J55 (13" Rotors), and be fine. But are there there any goofy restrictions on me using Grand Sport Calipers?
Earlier cars can't legally upgrade to the bigger rotors since that would take a non-Corvette caliper bracket. So long as you are swapping out stock parts for stock parts and not using somebody else's bracket and it all bolts up you are fine.
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Not unless you own a Grand Sport or intend to convert EVERYTHING over to one. IIRC, GS brakes calipers are different than the J55 ones, correct?
1 Post
So, what is special about the GS calipers to make them better? Just a thought, being a GS, wouldn't they come with the J55 option? If so you can change the calipers also since it comes together in a package.
The J55 was the option code for that years upgrade to 13" brakes. The Grand Sport Calipers were only available in '96 and they read "Corvette" on the caliper face. Since they were not available in '90, I didn't know if that would matter. I know there is some wording about changing within the model year range, but I wasn't sure how that works.
FWIW most of the fast C4 SP guys always went with the smaller brakes to save weight. The extra rotor will do nothing to help you on an autox course. Sure if it is a dual purpose car it would be nice to have the bigger brakes on a road course, but they are just more unsprung weight to carry around on a Solo.
In stock class the GS caliper is only legal on a 96' GS spec car.
From 2008 Solo Rules for Street Prepared category:
"15.1 AUTHORIZED MODIFICATIONS
C. Equipment and/or specifications may be exchanged between different years and models of a vehicle if (a) the item is standard on the year/model from which it was taken, and (b) the years/models are listed on the same line of Appendix A (Street Prepared Classes). The updated/backdated part or part to which it is to be attached may not be altered, modified, machined or otherwise changed to facilitate the updating/backdating allowance..."
Corvette ('84-'96) are on the same line in the Appendix for Street Prepared. Upgrading to the J55 brakes (which was a factory option for 1990 anyways) should be perfectly legal in B Street Prepared (or in A Stock class for that matter if the option change is complete). Upgrading to the Grand Sport calipers should be legal in Street Prepared, as long as you don't have to alter, modify, machine, or otherwise change something in order to use them... Just my .02
