Engine Drag Control Active
Old 04-10-2008, 10:12 PM
CodeBlack
CodeBlack's Avatar
Default Engine Drag Control Active
As a result of switching from stock tires on my C6z06 to Michelin ZP pilot sports, 275-35-18 front and 345-30-19 rears the engine drag control has started to activate. Can this be a danger on a road course?
Old 04-10-2008, 11:01 PM
mousecatcher
mousecatcher's Avatar
i don't see how. all it does is keep the throttle cracked so that the engine drag doesn't contribute to deceleration. (under the assumption and/or detection that the rear wheels are slipping.)
Old 04-10-2008, 11:12 PM
CodeBlack
CodeBlack's Avatar
Thanks for the info, I forgot to add that when I applied the brakes in a normal fashion the abs kicked in, not the warning light, the ABS itself is this something to be concerned over during road racing?
Old 04-10-2008, 11:14 PM
mousecatcher
are your tires NEW NEW? i found that the PS ZPs were slippery for the first few miles (say 100 or so).
Old 04-10-2008, 11:53 PM
CodeBlack
CodeBlack's Avatar
YES, BRAND NEW
Old 04-11-2008, 06:10 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
good-bye 7mm dry track here we come steel backing plate!
Old 04-11-2008, 09:35 AM
rustyguns
rustyguns's Avatar
huh?
Old 04-11-2008, 10:49 AM
John Shiels
Originally Posted by rustyguns
huh?
private joke
To Engine Drag Control Active
Quick Reply: Engine Drag Control Active
