First HPDE, Autox experience, couple questions
Hey guys,
BTW the first trailer run went quite well, thanks for the tips
Now I have another question, I am going to go up to Thunderhill for my first "track" event and have done a fair amount of AutoX with a mainly stock 01z (AR headers, Stinger, Tune). Suspension is all stock and car is lowered on stock bolts 3/4-7/8" front and rear.
I generally run Kuhmo V710's for my autox events, 275/40/17 front and 315/30/18 rear (30/35 can't recall) on OEM z06 rims. My question is do I run my Firestone Wideovals in stock sizes for my first event or run the V710's?
I have new ATE super blue en route for the brakes, rotors (Napa) have about 600 miles on them (10 miles of Autox) with stock z06 pads. Clutch fluid is Ranger refreshed regularly.
Thanks in advance for any tips you might have, I did do some searching but did not find anything specific on my tire question.
Thanks again
Fej
Thanks again
Fej
You are going to love Thunderhill. I suppose most people will tell you to run the Firestones for your first track event, I ran T1Rs for quite a few, before you move up. But, you have at least some AutoX with your V710 so it's probably not as important for you as it was for me. I had a great time with my T1Rs and no matter which tire you decide on, if you do decide to go pick some daisies, there aren't too many spots at Thunderhill where you'll get in big trouble. Have fun!
You might check with the people putting on the event.
many orginizations do not allow slicks for first timers.
your sort of in that class I'd want to take along both sets of tires just incase.
Going into #2 be about 3/4 of the way towards the outside of the track at the start of it. The outside of #3 is really off camber, turn in hard and stay on the inside half. Going over #9 let her track to the left a bit as your adding the last of third gear. Post how it goes when you get home.
If you have a lot of autocross experience then you'll just end up thinking of it as a big autocross course .
You might try upgrading to better brake pads such as Hawks or Porterfields is the only thing I can think of.
