08 ZO6 Shifter in a C-5
I know this subject has been beaten to death, and I have searched and read most of the posts on the subject.
The problem I am having with my 00FRC is shifting from 4th to 5th at speed. Sometime the shift is like cutting butter, sometimes it grinds as it hits reverse, and sometimes it goes into 3rd. Luckily when it went into 3rd I let the clutch out slowly and sensed the problem and re-shifted. Then if I can't get into 5th, I go to 6th for the rest of the straight a way. Not the hottest ticket. I will be running at Sebring May
24-25th, and I know I will need 5th gear before the end of the straight before turn 17.
I don't care about light ling fast shifts I am not a drag racer. I really don't even care if I have a short throw. I had a MGW shifter in my Cobra and extended the handle up and back 4 inches. Yes a longer throw but put the handle closer to the wheel, and the leverage of the longer handle made shifting easier.
Ok, so much for background. Base on what I have read here I have ordered a 08 zo6 shifter from Gene Culley. I understand I will receive the shifter and the mechanism that attach's the shifter to the trans shifting rod. From what I have read seems most people remove the shifter from the mechanism and install it in there old mechanics.
Now this seems like an easy way to go, but would I be loosing anything by taking this shortcut.
My shifter has 83k miles on it, I have to think there has been some wear on the mechanism (and the trans in general), that the new mechanism would help correct.
So what's the opinion of the form, replace the entire thing or not? And will performing the "washer" upgrade on the transmission help my 4-5 mis shifts.
Thanks,
Jay B
Thanks,
Jay B
St. Jude Donor '10-'11
... Sometime the shift is like cutting butter, sometimes it grinds as it hits reverse, and sometimes it goes into 3rd. ...
Now this seems like an easy way to go, but would I be losing anything by taking this shortcut.
Thanks,
Jay B
Thanks,
Jay B
Don has the "washer" upgrade; I do not. Mine feels more "gated" than his. I prefer mine.
Suggest bolting it in, screwing the **** on and test driving it before re-installing the console. Mine is VERY close to needing adjustment, as I have a hard time going into 1st at times.
If you're grinding reverse, possibly the reverse lock-out solenoid is bad?
You'll need a short boot as well ... got mine from Vette Essentials.
I have a 2000 FRC and installed the C6Z06 shifter last summer. It just bolts in very Quick And I kept the C5 boot. You just have to adjust it properly. It works great.
The entire assembly. It takes me about 15 min to remove the console cover and bolt the shifter in. I had to do this many times last year at the NCM VIR event. I had a clutch installed the week before and they broke the shifter mount so the adjustment would never stay. Just make sure when you install it to lock the adjustment pin on the shifter then align the notch on the shaft. There should be no tension on the shaft
I know an aftermarket shifter would come with instructions. But on a GM part I assume they think the tech knows how to install it or has the correct instructions.
SO...Is there a place on a forum that would have instructions or illustrations.
See post # 3 here for link to installation instruction with pics:
http://forums.corvetteforum.com/show...r+installation
More discussion on locking pin here:
Got my c-6 zo6 shifter from Gene Culley. After checking the references on this forum I dove into the project. I have had the console apart before so It went quickly. The whole job took about one hour give or take. I did some other chores (shift light )while the dash panel was off.
Bottom line, it feels better. Not night and day but better. Still don't like the 4th - 5th shift, but in playing around I found that a double clutch puts in into 5th cleanly every time.
1 Post
St. Jude Donor '08
I am aware or the anti-venom mod. I may try it but the comments seems to be that it takes out the "notchiness" feeling. I think I want the feeling of the "H" pattern. I don't want speed shifting I want precise shifts.
