Hardbar comes through again
St. Jude Donor '05-'08
I know I have said Gary's stuff is an investment and I mean it. He has thought of everything so that you and I do not have to build parts or cut stuff to fit.
again the seat rails have everything I need built in.
First the quality is top notch. He gives you plenty of fine adjustments so you can get the seat the exact way you want it.
Ok you should expect that, but there is more.
The YAW sensor is right where you would put the rails I called Gary and he said look at the predrilled holes because that is perfect alignment for the YAW sensor. Well that was easy.
So onto last night. I found out that I had to put my fire extingusher back in for this weekends event. I was kind of avoiding it because when I put in Gary's seat rails the studs were bigger and the BK bracket didnt fit. Well last night I figure I would drill the bracket bigger so it fit, but then I stopped and thought about Gary's setup. He has studs for the seats rails which are threaded on the inside so you can put another stud inside them.
Well looking through my toolbox I had 2 studs with nuts that fit perfectly. 3 mins later the BK bracket was attached without doing any modification to the bracket.
I appreciate all the time and effort Gary puts into his parts prior to them hitting the market.
1 Post
Cruise-In II Veteran
Thanks, we do make mistakes, but try to be the best. We did a special set of rails and harness for Chris Ingle. We powdercoated the rails white, and provided Chris with a red, white, and blue Teamtech. I think it is too pretty for Ingle...
The rails are first class stuff and look great! I also want to mention these harnesses too. They are specifically made to fit perfectly on a HANS. I found out this past weekend just how much nicer they are than standard belts. I drove a Viper with standard shoulder harnesses and they just didn't feel as secure as the Teamtech. The Teamtech also has velcro straps that connect the two shoulder harness at the chest which keeps them from spreading apart - a very nice touch! Great stuff!!!!!! Thanks Gary!!!!!
Be carefull not to re-installing that yaw sensor backwards. Ask me how I know...we'll a few weeks later and a couple trips to the dealer to trouble shoot active handling problems, and of course I installed the sensor backwards. You can't imagine how much it throws the system off.
and I can see your issue being a big problem just like moving it left or right
I can turn a 30 minute bleed job into an afternoon of thrills and spills (literally)
dont worry if you saw me last night thinking abbut how the heck am I going to drill through hardened steel BK bracket you would know I am in the same boat sometimes.
but if I did need to find that nut I would be taking the seat out. I think it is between the rail and the center tunnel which is impossible to get to.
Gary - please add camera mount ot my penske order
1 Post
Ok, those are in stock, want me to send it today?
My Penskes came in yesterday, in kit form. What we (Richard @lemd) will do tomorrow is partially assemble a front and a back with all of the new "T" bar (tested to over 4000 pounds!):
new clicker lower rear clevis with quick change pin:
and new upper clevis mounts
and go through the full range of suspension travel. One of the big advantages here of the Penskes is that we can change the body and shaft lengths in 1/2 inch increments to get the optimum travel both at full bump and full droop with maximum possible travel.
After that is correct, them we will assemble them, dyno them. These have a piston that is a linear on the rebound side and a VDP (Velocity Dependant Piston) on the compression side. The VDP has some very unique characteristics in that it is soft at very low shaft speeds, and has a rising rate at the high speed (shaft speed, not vehicle) so that the big slammer bumps/transitions don't hit so hard. If you are interested, see page 25 of the manual:
http://hardbarusa.com/PenskeManual.pdf
So, I am going to be very busy this weekend!
