C6 Kumho V710 hot pressure?
start temps are 29 front and 27 rear with ambient temps between 50 and 80. tires enter the pits hot around 38 front and 34 rear. fronts are smaller build more heat 285/30/18 front 315/35/18 rears.
on cold mornings i run 26 front, 23 rear, temps come in close to mid 30's
hot days 80 to 100 same as cold mornings but temps hit closer to 40.
hard to generally have a set rule, weather is always different, tires act different as they wear out and tracks are always different , more turns, rougher pavement etc i have started as low as 22 pounds and as high as 34 pounds
best rule of the thumb is to watch the sidewall wear. if it goes to far add air and visa versa
and never never go slow!
PS I luv Khumo V710! but you will get best times are with Hoosier R6's God Bless America
