Keeping Cool
St. Jude Donor '05-'08
Keeping Cool
I was thinking some of the coolers on my car
I guess they are working well together
30 min sessions at Pocono North oil temps were 240 high and coolant was 212 high
T1 tranny cooler - never had any issues with shifts
Power Steering cooler - my fluid was cooler than a customer's C5Z without the power steering cooler
Rotor cooler - matched my rotor temps to others and mine were down.
I realize some of this is driving style, but I am happy knowing that I have added the correct cooling components to extend the life of my car.
Now its time for a cool suit to keep my temps down
- Dewitts radiator with EOC
- T1 Tranny Cooler
- Power Steering cooler
- Rotor cooler - ECS Spindle ducts with DRM extentions
- T1 Tranny Cooler
I have 2 power steering coolers from a C6. They work which is what matters. I agree with the T1 cooler is over priced and there probably a better setup, but I bought it 3 years ago so I am stuck with it.
I think the T1 cooler is fine. You only have a limited space to put coolers (assuming it is mounted in front of the radiator), and going larger is only going to steal more air from your radiator/oil cooler. My only problem with the T1 setup is that the pumps tend to fail too soon. Maybe install an inline strainer. You can get cheaper replacement pumps from HRP when the time comes.
I ran LG's diff-powered mechanical pumps on my last WC car, and that is a slick setup. It is a lot of work up front, but it's very clean once installed. Priming the system after a refill does take a bit long though, as you have to run the drivetrain to turn the pumps, not just flip a switch.
Dewitt EOC is awesome piece of art! That is the one thing I greatly miss from my C5. The temps were so low, it was ridiculous. On the street the car would run at 160-165F and oil never got above something like 220ish if I remember correctly.
my PS cooler is 8' x 12" 1.75" does a great job. Diff and tranny coolers are from DRM in the rear ducts
