Suggestions for Clutch?
After some minor slipping probs at VIR last month and some major sticking at the drag strip Saturday, it is time for a new clutch. Search shows nothing except for flywheel discussion. What would be a good choice? Car is a daily driver when not raining, it sees the track once a month at VIR or Rd Atl and maybe CMP. I also would like to go back to the drag strip again but that will be a rarity. My tuner is an authorized Bird of Prey installer who happened to be at the strip Saturday. He said it would be ~$1,700 for the Talon clutch install . I can get the Talon delivered to my door for $1,099 so around $600 for install(?). Also, the car has 551 rwhp and 453 rwtq and probably will not have much more. Suggestions? I would only like to do this one time. Thanks for the input.
Location: If you don't weigh in you don't wrestle Road America
I've heard good things about the RAM street dual disc (around $1300) and the RPS twin (around $2500). I think at 550 whp you are pushing the limit of the single disc clutches, especially if you are going to be driving the car on the street a lot. Any single tough enough to handle the power will have a heavy pressure plate and be a bear on the street.
Otherwise give Tom at Carolina Clutch a call, he'll find something for you.
ram
I am also on the ram clutch I moved from the textrillia (spelled it wrong) to the Ram clutch and am very happy... While i am not at the power levels you are (bout 409 RWHP here) I have used it on the 1/4 mile Maxton mile as well as VIR and it has never missed a beat. Good product from what i have experienced.
I just put a Spec 3 clutch in my white FRC. No more stick problems at all but it is a bit digital for street use. I would go with a Spec 2 or 2.5 for a street car.
I would not install a clutch for less than $750 - a little more if it has headers...I think GM estimates the job at 12 hours...
I would also put in a new slave and remote clutch bleed while I was in there.
St. Jude Donor '05-'08
Well I would go with the exo textrailia at your power level although I have 565 rwhp / 540 rwtq and the single is working just fine in my car. I installed it last year at 460 rwhp and 401 rwtq for RR and it was great. A year later I was taking it out when I put in the LS7, but it looked new and the exo was on back order. I have had it out for 3 RR days so far with no issues.
WGI this week will be another test.
What about the LS7 clutch?
Can that hold 550 rwhp?
Wicked Weasel - is the exo what you have now?
Varkwso - I had ruled out the Spec 3 because of the dd; I will check out the 2.5
RaleighSS - I have heard of the RAM; off to research it.
Right now I am leaning towards the CF dual friction or the McLeod. Just have to decide if I want to do aluminum flywheel or not. It is probably now or never, as hopefully this will be my last clutch job.
Thanks guys.
Thanks guys.
Also, for road course use: billet steel or aluminum flywheel?
Is there a kit somewhere for the remote bleeder?
So while I'm having my tranny repaired and we're in there it only makes sense to do the clutch. I don't know how much I'm in for on the repair yet, but was thinking of the SPEC Stage 2 even before. Have heard good things and it's inexpensive. How would the LS7 clutch compare in cost and performance. Cost on the RAM anyone?
I run a Spec aluminum in our white FRC - the Al flywheel and clutch are the way to go for road course - they are some discounts available if you shop vendors.
You do not need a kit - it is a long hose replacing the short bleed valve - I think I got mine from LAPD or some such.
I have narrowed my choices down to the CF Dual Friction, $414 shipped or the Spec 3+ at $538 shipped. I would prefer the CF because of the dd thing, but my installers likes the Spec and says I would have no issue with the Spec with dd. Thanks for the all the good info. I hope someone in the future can use it.
"...I would have no issue with the Spec with dd" I have a little over 500 miles street use and one+ track day at CMP - streetable a SPec 3+ is not in my opinion. It is a digital clutch at the moment.
Also you are getting the Spec 3+ flywheel, throwout bearing, pilot bearing, spacer (use it!), clutch, pressure plate and installation tool for $538? That is really, really low - check to see if they are getting it all - you really want to use their whole setup.
It does not incl flywheel, but I thought I read I could use my stock one, resurfaced if necessary. I will go back and re-check. Thanks.
I went with the CF DFC after my stock C5 and later my Z06 clutch would slip and stick. I have 425rwhp and its holding perfect. If you do go with the CF, make sure you get the 12" not the 11". The 12" is rated up to 650rwhp.
