China Rotors - Poor Results
Just cracked my first front China rotor. I got 207 track miles.
The last three sets of Canada rotors lasted an average of 352 miles (i.e., 358, 370 & 328 miles).
That's only 60% the longevity for the China rotors compared to the Canadian. Not good.
FWIW, same tires (RA1), same pads (PFC-01) and same track (Hallett).
Rick
Rick
Rick
Rick
Rick
Rick
Rick
Rick
I am not saying that you are not right and that you data won't prove out with further data collection, but I am not sure one rotor is a conclusive test. There are many variables besides your tires, pads and track. Most notable would be weather conditions, the conditions of your brake ducts, how hard you are driving, etc.
From the very limited sample of data you provide on how many mile you have gotten out of previous rotors I could suggest that perhaps you are getting faster and there fore harder on the rotors. Your current data points on Canada rotors is ultra-limited, but perhaps it shows you are going deeper into the turns.
I think maybe after 10 sets of rotors a more conclusive result can be derived unless earlier tests show substantially lower longetivity on virtually every test sample.
...but what do I know...
Frank Gonzalez
FG, you may well be right, I am just not ready to conclude that just, yet....
...I am sure you have done the same, but I have cracked the Canadian rotors in one day before. The best lasting ones I ever used I got used from Orange County Corvette. They were pull-offs that came off a street car that got a big brake kit. The rotors were very well "seasoned" from some street use and they seemed to last forever....
FWIW, brake cooling ducts are in the same, "good" condition. No less air flow than with the Canadian rotors.
Also, to be fair, I believe I put the China rotors on in the "middle" of a track day and immediately hit the track. I don't think I seasoned them prior to hammering. However, I can't remember as it was the end of last season that I installed them. I'll go through my log book to verify and post.
I could be providing bad data....... I've had good service with many China made items and am not a China basher by nature.
Rick
Maybe the rotors are OK, but I will try to keep buying Canadian, Brazilian or whatever else.
Frank Gonzalez
The first year I did DEs I would go though rotors every two events. As I did more and more events, the front rotors lasted up to 5 events, and rears up to 7 events.
For the most part it was three events for the fronts and 7 events for the rears. I used PFC-01 or Wilwood H brake pads.
My braking style changed with more experience. Braking latter, harder and shorter duration. Plus I did a better job of bedding or seasoning the rotors in before going to the track. AND doing more cooling down after each session.
As we have mentioned in other threads, almost all one piece brake rotors are now made in China, no matter whos name is on the box. Even many of the two piece rotors with big names are cast in china, then finished in some other country. And as Frank mentioned "they only know how to make things one way, Cheap."
Brake rotors are disposable items when you start tracking your car. That is a fact and you just plan and budget for that.
If you want a two piece rotor set up that is great. There are several out on the market place, my choice would be Colman Racing out of Mich. IIRC Colman makes almost all of the NASCAR brake rotors and can make anything you want, but you need to know the demotions.
Or you could go with Hitco. Hitco makes the F1 carbon rotors and brake pads
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
No picture available. They're in the trash can at the track.
Not sure what you're expecting to see? It's just a cracked rotor, nothing new or special about it. No different than the 100's that people crack with regularity when subjected to track usage. Crack(s) across the braking area perpendicular to the OD of the rotor.
Rick
Rick
I did a search for you. Here's a picture of a typical crack:
http://www.petting-zoo.net/corvette/...MG_0806-r.html
Do a Title Only search on "cracked rotor" and you'll have a lot of reading material and pictures.
Rick
Rick
Rick
Rick
My Wife is using them to make a path though the garden. I Keep 12 for when I do alignments. Put them in the drivers seat to act as 200 lbs of me.
But with the prices of scrap iron a few dozen might pay for a track weekend now
$11 for 100 pounds of scrap iron here - gets much higher I will be mining my driveway...
