Front adj sway bar links 101 - need help
I've got some for 04 c5z & staying with the stock bar for now. Should I put these on? How do you use the length adjustment in them?
Is it simply that after you lower & corner weight (links off) then you just set them up with zero/neutral tension?
Or do you preload/unload the bar with them?
Thanks.
Is there a chassis setup for dummies book?
Thanks.
