The Answer for SCCA Super Stock Sway Bars
Former Vendor
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
Pfadt Race Engineering is proud to announce the release of its new Super Stock Sway Bar!
We have developed a sway bar for the C5, C6 and C6 Z06 that is specifically designed for competition in SCCA's Super Stock class. The Super Stock class only allows competitors to change the front sway bar. So we took the SS rules and created a sway bar package that will help you dominate the competition.
The Pfadt Race Engineering SS Sway Bar features:
Pricing on all Super Stock Sway Bars is $550
Please visit our website for a complete description!
- Matched Front Bar to the Factory Rear Bar
- Adjustable Rate
- Fully Adjustable, Teflon Lined, High Strength Rod Ends
- Polyurethane Bushings
- 4130 Chromoly Bar with Spines Cut Directly into the Bar
- Splined 7075-T6 Billet Aluminum Arms
- High Quality Hardware for a Professional Install
- Lighter Weight Than Stock Front Sway Bar
Do you have the stiffness and weight comparison to say:
Stock C5Z06 front bar
Addco 32mm front bar
Hotchkiss 32mm front bar
GM T1 38mm front bar
EDIT: I found this as I knew you had something like this which helps:
Where does any of the above bars fall on that plot (other than the T1)? Which bar is the Super Stock bar, I assume the front Street Pfadt bar? What does the whole bar assembly weigh versus the above (at least stock as thats a pretty good reference point).
