Anyone have VBP Poly Bushings?
OK, so I had a local tuner change out all my stock bushings on my 97 coupe with VBP polyurethane bushings. Now, the entire car creaks like crazy when I go over uneven surfaces. I gave the car back and told them to fix it. They called me and said it was all done and much better. I just picked it up and there is no improvement. Has anyone else intalled these particular bushings? Did you have loud suspension creaks afterward?
NOTE: Also put in Z06 sways, springs, and shocks at the same time. Told shop to relube them as well when the car went back.
I have VBP poly bushings installed by a very trusted shop who used aircraft lubricant and it squeaks. They re did it and after awhile, still squeaks.
I think i will call Aaron and try some Pfadt's.
All poly bushings creak with time - fact of life. I love my VBP bushings for the performance they give.
If you put adj end links on your sways that is the source of most of your noise. I only run one adj end link per sway (reduces cost and noise)
This is creaking like crazy right out of the shop. Not months or years later.
Lubed everything on mine. End links (T-1), bushings, sway pillow blocks, everything. Make sure shock attachment points are tightened down too. No squeeking. Pfadt bushing set, all four corners. Very nice.
I used lots of lubricant & have not heard a bushing squeek. With poly bushings, VBP springs, Pfadt camber plates, T-1 bars, & revalved Bilsteins, I can't hear anything but the sweet music of long tubes & GHL Bullets under serious acceleration! And, it corners like it's on rails!
-TJ
PS- I still have that cargo cover thing for you, I have it w/ me at work.
