Speaking of brakes....
I just prepped my car for the races next week at Robling Road and found something that I was pleased with.
I was at CMP last weekend for 2 pratice sessions, 2 qualifying sessions and 2 races, and you guys who have run there know how hard that track is on brakes. I started the weekend on a brand new front set of BHP pads and they wore fantastic. The brakes were flawless all weekend and after measuring them, there was still 10/32"s still left on the pads that started at 12/32"s.
I was really impressed with the wear, and the stopping is as good as the Wilwood H's. Rotor wear is no worse, and I'll be using the same rotors at Roebling next weekend.
Very easy to warm up. They're ready within 1/2 a lap if you accelerate and brake hard numerous times during that lap. I do that instead of the squiggling back and forth on the out lap. The accelerating and braking puts heat in the tires.
Cruise-In VI Veteran
Jody, I will be trying a set of these shortly. Which ones do you recommend for my use? All I will be using these for is track only. Use stock pads for the street. I use sticky tires on the track.
Bob
A lot of people don't realize that that is the best way to heat up tires and brakes. Swerving cleans the tires from all the junk that sticky tires tend to gather so I combine the 2 on the out lap.
Bob
Bob
Here's a link: BHP Brakes
1 Post
Call BHP and talk to Matt he will get you setup with everything. Also they have a brake fluid that was tested that exceeds Motul and ATE. I switched to BHP and this fluid. Great combo. Ran Road Atl and CMP. BHP pads are very durable.
Here is the phone number: 704-489-8399 phone
As lbarnard says, the GS 610 fluid has a higher wet boiling point than ATE and other fluids I'm familar with.
The bedding process of these pads is good, too. I bedded mine to brand new rotors during a practice session 2 hours before the race.
I slowed quickly from 20 to almost stop, 40 to almost stop and then 60 to almost stop. That was it. They were good to go in qualifying and the race 2 hours later and never a shutter at all during the weekend. And the rotors are good to use next weekend.
I've been testing some BHP pads on the Z06 as well (not available yet to the public I'm told), and I'm very impressed as well. They are noisy on the street, but perform and wear very well. I don't know about the C5/C6 pads, but on the Z06 they have a very high initial bite, but once you get used to it they have worked very well.
Hi guys, thanks for the kind words.
I've had a ton of email inquiring about prices, so I figured I'd just post that info up. All C5 and C6 non-Z06 pads are identical, and they are $229 front, $200 rear for PR1 compound. The GS610 fluid is $15/bottle (500ml).
Right now, we have no dealers, and you can only buy these direct from us.
Edit: Just to clarify, all C5 pads are the same. Base, Z06, doesn't matter. All C5 pads are identical. That pad carries over to all non-Z06 C6 models. Base, Z51, doesn't matter. All the same.
Clear as mud?
Matt
Clear as mud?
Matt
