How the heck do I get -2.5 degrees of camber??
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
I keep destroying my Hoosiers, which recommend -2.5 to -3.0 and the best the Goodyear dealer can do is -1.5
Help
Help
Received 8,928 Likes
On my 97 I was able to get -2.2 to -2.3 depending on side by setting the camber and letting the caster fall where it would fall. If the car had been lowered (the GM recommended amount) it would have probably picked up a few more tenths of a degree of camber. This was with the cams run all the way out and all washers removed from behind the upper control arms.
Bill
Bill
Didn't check the rear. When we were going through setting mine up we cranked them all the way in to see what it could do. walla -2.2 I was shocked. I eneded up pulling them back out to -1.5 since I'm still on street tires.
As far as tire wear you don't need as much negative camber in the rear. I never had more than -.8 in the rear and the Hoosiers wore fine.
Bill
Bill
make sure the upper control arms don't have WASHERS behind them, most cars have one or two behind each bolt. Each washer is good for about .5deg. Also, as stated, either GM, Pfadt, or Hardbars camber plates will give you another .2deg or so.
They likely coult only get -1.5 and maintain your castor setting....If it's mostly a track car, you can sacrifice the castor for more camber.
CI-7-8-9-10 Veteran
C6Z06s have two washers between the upper control arms and the frame. You need to remove the bolts that mount the control arm to the frame to take out the washers. If you remove one of them you gain about 0.5 degrees of negative camber.
With both washers out (8 total for the front of the car), I get -2.8 to -3.4 degrees in my car.
You should not have any problem getting -2.8 degeres.
Frank Gonzalez
Frank Gonzalez
