Trailer Tires
Trailer Tires
I have had several tire failures on new tires in the past year on my enclosed car trailer. Following the first, I am a stickler on air pressures and being within the load limits of the tires. I use a weight distribution system so don't think overloading the tires are the problem. The last occurred this past Sunday on the Natchez Trace at 50 mph in cool temps.
I'm curious which trailer tires folks are using on trailers.
When I bought my 18' dual-axle open trailer it came with some cheapie Chinese brand tire. While they seemed to be fine for the most part (quiet, smooth ride with no balance needed) I didn't really care for the idea of having 5400lbs of weight supported by tires I knew nothing about or had never even heard of.
So now I have a set of 4 Goodyear Marathon tires in ST 205/75R-15 Most of the people I know with enclosed trailer have Goodyears.
I've had various brands on my trailers and I'm currently running Carlisles on my 24' enclosed utility trailer because they are cheap and available at any Discount Tire. I don't recall whats on my 5th wheel. When I replace the original trailer tires I always go up at least one load rating higher and I insist they use the high pressure valve stems required for E load range tires which use 80psi. You would be suprized how many tire installers don't even know the difference and will put a low load car valve stem in a high psi truck or trailer wheel.
My utility trailer came with load range C tires. I had a few blow outs and eventually all the tires were replaced with E range tires and the 80 psi stems. No problems since. I had to go with a wider tire to get up to the E load range (225/75/15 instead of 205/75/15). Luckily my trailers fenders provide plenty of clearance so that was not an issue. They are only about $10 more each - $115 at Discount Tire for the Carlisle radial trail brand. Discount Tire has an online tire calculator so you can compare sizes and the difference in width, hieght, diameter etc.
When it was time to replace tires on my previous travel trailer I bought a set of cheap white steel 16" wheels for $35 each. I did that so I could increase the ground clearance of my trailer by going with 235/80/16s instead of the smaller 205/75/15s. I gained almost 2" of clearance which made getting in and out steep gas station driveways easier and the weight rating was much higher as well.
Don't let the tire guy try to convince you to that you don't need the higher load range stems even if you only upgrade to a D load tire with only 60psi. Get the heavy duty stems.
We use GOODYEAR TRAILER TIRES-not car tires.
http://www.redtrailers.com/ListItems.asp?cat=6
Being a stickler on air pressure could mean a lot of things. I found that if the max was 90 psi, you'd better be 90 psi or more. Running less, which some do for a softer ride and less bounce, will heat the tire more and separate the tread.
Like the others have said, be sure they are trailer tires and not car tires. They need to be an ST tire size, although I know some people who ran LT (light truck) successfully. Of course, they were rated much heavier than a car tire.
Most trailers I have checked years ago seemed to come on the minimum tires necessary to get it off the dealer's or manufacturer's lot and hopefully a day or two away. Don't scrimp on them, because unlike tires on your car or truck, you usually won't know one has gone down until you see chunks flying off in your rear view mirror.
Goodyear's Marathons have been great on my trailer. I use my open trailer for construction business with thousands of miles on them with the weight of up to 10,000 lb. I have replaced a few but never the tires fault. They are not cheap like 165 ea.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Ron, JO says he never had any longevity with 15" tires, whether E load or anything other load rating. He finally went to 16" wheels on his current trailer and has not had a problem. I, too, find the 15" tires pop. I need to find a good GN with 16" wheels...
I bought a new WellsCargo trailer and 1 tire shredded on the first trip - about 300 miles. There wasn't enough tire left for them to look at for defect. I had to drive on it for ~7 miles because there was no exit or shoulder to pull off on.
I noticed I had another tire losing air. I found a nail in center of tread. When the shop looked at it there was a larger hole and soft spot in the tread about 5-6" from where the nail was. The trailer isn't even a year old. I bet I don't have 2,000 miles on it.
Both tires were the rear tires.
My dad always said trailers are bad because the front tire will kick up a nail/object where it is more likely to stick in the rear tire. No scientific survey to back him up - just experience I guess.
Also, trailers usually sit outside in one place for long periods of time. The tires will weather and age faster than cars/trucks that are driven more.
I'm going with a heavier ply tire and watching my tire pressures.
2 down (replaced) - 2 to go
I went to Harbor Freight and got the tire covers that people usually put on RV's that sit outside. Easy on and off and saves the trailer tires from direct exposure to the sun. HF has them on sale fairly often for like 10 bucks for four covers.
the only time I had tire problems was when I overloaded a 28' pace trailer. If you are absolutely sure you are not over the rated capacity of the tires (printed on the sidewall), then I'd have a serious chat with the manufacturer.
I irony of my situation was that if I would have bothered to stop and weigh, I could have easily move a few hundred pounds of cargo from my trailer to my truck, and I'd have been fine. Instead, I ended up chasing tires all over the east coast during a NC to Lime Rock to Mid Ohio 2-week tour! Not fun!
I have two spares and plugs with me. Never had a problem except from road hazards and when a fender popped off to rub the tire and run it. GY tires have been great.
Marathons of the right load range(or maybe one higher) inflated to the max allowable on the sidewall. Load Range D in my case, never had any problems.
Frank Gonzalez
