Brake Pad Question
Brake Pad Question
Looking for some feedback from the road racing folks here ... what would you consider the best "performance STREET brake pad" for occasional HPDE/track use to be? Characteristics in order of importance is zero street noise then grip on track and last dust production.
Cruise-In VI Veteran
Any pad you get that is made for any track use will have noise and dust. The best I have found are either Hawk HP Plus or Carbotech Panther Plus. Ceramics are no good for track use.
Bob
Bob
I like HP-Plus, espcially for C5's and non-Z06 C6's. If you reach speeds over 160 a lot, they tend to wear too quickly and require a lot of pedal pressure. They are pretty quiet on the street however
ok
Let me re-phrase the question ... short of a true "race/track pad," are there any street performance pad options you folks would consider to be better than the OEM C6 Z06 pads for occasional HPDE use?
None do both unless you are just starting to drive at the track. If you are pulling any types of speeds you will end up in trouble.
St. Jude Donor '10-'11
Don't know if they make them for the C6Z but on a C5Z I use Carbotech XP10/XP8 for the track with street tires and leave them on for limited street driving.
I am finishing off a set of HP + doing AutoX (had previously used them on the track, after Z06 pads gave out)
I was going to say Hawk HP+ as well, they have a ton of street bite and do okay at the track hot...not great, just okay. But I disagree with David...they are noisy. They also dust very bad. Long story short, they are IMO the best street/track pad from a performance point of view. They dust and squeal.
Honestly, I'd say OEM Z06 pads. Similar to HP+ with less noise. (but still some noise)
